2022-03-02 01:49 AM
TouchGFX does not recognize if changes have been made into this file externally.
Reproduce: make changes in assets\texts\texts.xml file -> regenerate with Designer -> texts/src/LanguageXXX.cpp source files are not regenerated properly.
Fix: make changes in Designer -> regenerate -> files are now regenerated properly.
Hopefully will be fixed. We edit assets/texts with scripts, and this workflow is not good.
2022-03-03 09:25 PM
Hello Tuoman,
I cannot reproduce your issue.
Can you be more precise on how to reproduce the issue (with images to illustrate if possible) ?
The easier it is to understand the problem the faster it can be fixed :)
/Alexandre
