2017-06-16 6:08 AM
I'm using NucleoF207G in that I'm trying to freertos queue using STM32Cube but i can't able to create any queue using xQueueCreate API . Pls give me a Proper suggestion .
-Thanks
K.Manikandan
2017-06-16 8:36 AM
Hi
K.Manikandan
,You can refer to a typical
FreeRTOS
examples and use CubeMX to build and generate your project with FreeRTOS.STM32Cube_FW_F2_V1.6.0\Projects\STM322xG_EVAL\Applications\FreeRTOS
I recommend to you the following references, it maybe helpful for you:
/external-link.jspa?url=http%3A%2F%2Fwww2.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Fuser_manual%2F2d%2F60%2Fff%2F15%2F8c%2Fc9%2F43%2F77%2FDM00105pdf%2Ffiles%2FDM00105pdf%2Fjcr%3Acontent%2Ftranslations%2Fen.DM00105pdf
Imen
2017-06-17 12:11 AM
Hi Imen ,
I have that document too but , i want to know what is the prob when I'm using xQueueCreate API . I think problem with Heap memory settings but cant able to troubleshoot it , so i need help..
-Thanks
K.Maikandan
2017-06-17 12:54 AM
In STM32Cube_FW_F2_V1.6.0\Projects\STM322xG_EVAL\Applications\FreeRTOS what is the stack size and heap size for Linker settings in STM32Cube ?
2017-06-20 2:55 AM
Increasing queue size ,
https://community.st.com/0D50X00009XkY4MSAV
is working . But i had another one doubt , I want to send data to queue from CDC_Receive_FS and receive the data from another threat .Any Idea ?
- Thanks and regards
K.Manikandan
2024-08-23 9:15 AM
People who searching for an answer:
What worked for me:
