two UART DMA with timer interrupt
‎2021-08-24 12:39 AM
Hi, all
I am trying to receive packet from uart3 and send them to uart2
but the results of my trials are:
- transmit occurs every main cpu clock
- transmit occur just once
which I thought was:
- receive packet from uart3 when packet arrived, independently
- transmit that packet once for every 65ms
My problem is "once" and "every 65ms"
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart) {
HAL_DMA_Abort_IT(&huart2);
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) {
HAL_UART_Receive_DMA(&huart3, (uint8_t*)b, 2);
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) {
HAL_UART_Transmit_DMA(&huart2, (uint8_t*)b, 2);
It's what I tried, "b" is uint8_t array
Thanks.
DMA
Interrupt
STM32F4 Series
TIM
UART-USART
‎2021-08-24 1:02 AM
Hello @Frogram​ and welcome to the Community :)
Please take a look into the STM32 UART DMA RX/TX application note contains explanation with examples.
Hope this helps you!
Imen
Imen
‎2021-08-24 1:02 AM
Imen
Imen
‎2021-08-24 1:06 AM
Thanks!
I will check them right now
‎2021-08-24 5:40 AM
I have no idea how to apply this in my project... TT
‎2021-08-24 11:19 AM
You don't need to call HAL_DMA_Abort_IT at the end of a completed transfer.
The other calls should work. Consider simplifying the problem by removing the timers and implementing a fixed delay. Toggle a pin instead of using UART to verify timings. Monitor return value from HAL calls to ensure they succeed.
‎2021-08-24 11:32 PM
/*inside of main*/
HAL_TIM_Base_Start_IT(&htim6);
HAL_UART_Receive_DMA(&huart2, (uint8_t *)b, 8);
/*outside of main*/
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim){
if (htim == &htim6) {
HAL_UART_Transmit_DMA(&huart3, (uint8_t *)b, 8);
It worked! thanks all
