STM32L072CZ EXTI PB14 RISING FALLING ok. How do I activate PB13 and PB15
SPero.1
I would like to activate the RISING FALLING function also on PIn 13 and 15 but I can't do it.
I'm probably not able to edit several files that I list
6 REPLIES 6
SPero.1
main.c add exti15
int exti_flag=0;
int exti15_flag=0;
void send_exti(void);
void send_exti15(void);
switch_status=HAL_GPIO_ReadPin(GPIO_EXTI_PORT,GPIO_EXTI_PIN);
	if(exti_flag==1)
		AppData.Buff[i++]=(switch_status<<7)|(sensor_data.in1<<1)|0x01;
		exti_flag=0;
	else
		AppData.Buff[i++]=(switch_status<<7)|(sensor_data.in1<<1);
	switch_status15=HAL_GPIO_ReadPin(GPIO_EXTI15_PORT,GPIO_EXTI15_PIN);
	if(exti15_flag==1)
		AppData.Buff[i++]=(switch_status15<<7)|(sensor_data.in15<<1)|0x01;
		exti15_flag=0;
	else
		AppData.Buff[i++]=(switch_status15<<7)|(sensor_data.in15<<1);
	if(exti_flag==1)
	 Send( );
	if(exti15_flag==1)
	 Send( );
SPero.1
gpio_exti.c add EXTI15
void  GPIO_EXTI_RISING_FALLINGInit( void  )
	GPIO_InitTypeDef GPIO_InitStruct={0};
	GPIO_EXTI_CLK_ENABLE();
	GPIO_InitStruct.Mode =GPIO_MODE_IT_RISING_FALLING;
	GPIO_InitStruct.Pin = GPIO_EXTI_PIN;
  HW_GPIO_Init(GPIO_EXTI_PORT, GPIO_EXTI_PIN, &GPIO_InitStruct );
	/* Enable and set EXTI lines 4 to 15 Interrupt to the lowest priority */
  HAL_NVIC_SetPriority(EXTI4_15_IRQn, 2, 0);
  HAL_NVIC_EnableIRQ(EXTI4_15_IRQn);
void  GPIO_EXTI15_RISING_FALLINGInit( void  )
	GPIO_EXTI15_CLK_ENABLE();
	GPIO_InitStruct.Pin = GPIO_EXTI15_PIN;
  HW_GPIO_Init(GPIO_EXTI15_PORT, GPIO_EXTI15_PIN, &GPIO_InitStruct );
SPero.1
gpio_exti.h add EXTI15
void  GPIO_EXTI_RISING_FALLINGInit( void  );
void  GPIO_EXTI15_RISING_FALLINGInit( void  );
SPero.1
stm32l0xx_it.c add GPIO_PIN_15
void EXTI4_15_IRQHandler( void )
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_4 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_5 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_6 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_7 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_8 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_9 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_10 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_11 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_12 );
  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_13 );
//  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_14 );
 if(__HAL_GPIO_EXTI_GET_IT(GPIO_PIN_14) != RESET)
	 __HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_14);
		HAL_NVIC_DisableIRQ(EXTI4_15_IRQn);
	 if(inmode!=0)
	 exti_flag=1;
   HAL_GPIO_EXTI_Callback(GPIO_PIN_14);
//  HAL_GPIO_EXTI_IRQHandler( GPIO_PIN_15 );
 if(__HAL_GPIO_EXTI_GET_IT(GPIO_PIN_15) != RESET)
	 __HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_15);
	 if(inmode!=0)
	 exti15_flag=1;
   HAL_GPIO_EXTI_Callback(GPIO_PIN_15);
SPero.1
stm32l0xx_hw_conf.h add EXTI15
#define GPIO_EXTI_CLK_ENABLE()   __HAL_RCC_GPIOB_CLK_ENABLE()
#define GPIO_EXTI_PORT          GPIOB
#define GPIO_EXTI_PIN           GPIO_PIN_14
#define GPIO_EXTI15_CLK_ENABLE()   __HAL_RCC_GPIOB_CLK_ENABLE()
#define GPIO_EXTI15_PORT          GPIOB
#define GPIO_EXTI15_PIN         GPIO_PIN_15
SPero.1
Hello to all
I managed to run 5 EXTI but I always have a problem on the sent values ​​instead of getting the byte 00 I get random strange values, I also added a resistance of 4k on all EXTI the values ​​seem stable but they are not 00
PA1 = 0e
PA4 = 28
PB13 = 07
PB14 = 00
PB15 = 80
how do i get 00 and 01?
My code is this
switch_status1=HAL_GPIO_ReadPin(GPIO_EXTI1_PORT,GPIO_EXTI1_PIN); //PA1
	if(exti1_flag==1)
		AppData.Buff[i++]=(switch_status1<<7)|(sensor_data.in11<<1)|0x01;
		exti1_flag=0;
	else
		AppData.Buff[i++]=(switch_status1<<7)|(sensor_data.in11<<1);
	switch_status4=HAL_GPIO_ReadPin(GPIO_EXTI4_PORT,GPIO_EXTI4_PIN); //PA4
	if(exti4_flag==1)
		AppData.Buff[i++]=(switch_status4<<7)|(sensor_data.in14<<1)|0x01;
		exti4_flag=0;
	else
		AppData.Buff[i++]=(switch_status4<<7)|(sensor_data.in14<<1);
	switch_status13=HAL_GPIO_ReadPin(GPIO_EXTI13_PORT,GPIO_EXTI13_PIN); //PB13
	if(exti13_flag==1)
		AppData.Buff[i++]=(switch_status13<<7)|(sensor_data.in13<<1)|0x01;
		exti13_flag=0;
	else
		AppData.Buff[i++]=(switch_status13<<7)|(sensor_data.in13<<1);
	switch_status=HAL_GPIO_ReadPin(GPIO_EXTI_PORT,GPIO_EXTI_PIN); //PB14
	if(exti_flag==1)
		exti_flag=0;
	else
	switch_status15=HAL_GPIO_ReadPin(GPIO_EXTI15_PORT,GPIO_EXTI15_PIN); //PB15
	if(exti15_flag==1)
		exti15_flag=0;
	else
I'm not a programmer I'm learning by copying part of code, I'm definitely writing random things
If you can help me, you will be grateful
