stm32h750 vb adc+dma LLlib issue
mize
Spoiler
HELLO,
I have 2 issues
1. A bug report
CubeMx generated init code is wrong with LL lib
the marco config is not change from HAL to LL
2. I cannot enable dual ADC1/ADC2 continous conversion with dma, and at every tranfer finish trigger a intterupt
below is my code
/* ADC1 init function */
void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
LL_ADC_InitTypeDef ADC_InitStruct = {0};
LL_ADC_REG_InitTypeDef ADC_REG_InitStruct = {0};
LL_ADC_CommonInitTypeDef ADC_CommonInitStruct = {0};
LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
/* Peripheral clock enable */
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_ADC12);
LL_AHB4_GRP1_EnableClock(LL_AHB4_GRP1_PERIPH_GPIOC);
/**ADC1 GPIO Configuration
PC4 ------> ADC1_INP4
GPIO_InitStruct.Pin = LL_GPIO_PIN_4;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/* ADC1 DMA Init */
/* ADC1 Init */
LL_DMA_SetPeriphRequest(DMA1, LL_DMA_STREAM_4, LL_DMAMUX1_REQ_ADC1);
LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_STREAM_4, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_DMA_SetStreamPriorityLevel(DMA1, LL_DMA_STREAM_4, LL_DMA_PRIORITY_VERYHIGH);
LL_DMA_SetMode(DMA1, LL_DMA_STREAM_4, LL_DMA_MODE_CIRCULAR);
LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_STREAM_4, LL_DMA_PERIPH_NOINCREMENT);
LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_STREAM_4, LL_DMA_MEMORY_NOINCREMENT);
LL_DMA_SetPeriphSize(DMA1, LL_DMA_STREAM_4, LL_DMA_PDATAALIGN_WORD);
LL_DMA_SetMemorySize(DMA1, LL_DMA_STREAM_4, LL_DMA_MDATAALIGN_WORD);
LL_DMA_DisableFifoMode(DMA1, LL_DMA_STREAM_4);
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
LL_ADC_SetOverSamplingScope(ADC1, LL_ADC_OVS_DISABLE);
ADC_InitStruct.Resolution = LL_ADC_RESOLUTION_16B;
ADC_InitStruct.LowPowerMode = LL_ADC_LP_MODE_NONE;
LL_ADC_Init(ADC1, &ADC_InitStruct);
ADC_REG_InitStruct.TriggerSource = LL_ADC_REG_TRIG_SOFTWARE;
ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_DISABLE;
ADC_REG_InitStruct.SequencerDiscont = DISABLE;
ADC_REG_InitStruct.ContinuousMode = LL_ADC_REG_CONV_CONTINUOUS;
ADC_REG_InitStruct.Overrun = LL_ADC_REG_OVR_DATA_OVERWRITTEN;
LL_ADC_REG_Init(ADC1, &ADC_REG_InitStruct);
ADC_CommonInitStruct.CommonClock = LL_ADC_CLOCK_ASYNC_DIV1;
ADC_CommonInitStruct.Multimode = LL_ADC_MULTI_DUAL_REG_SIMULT;
ADC_CommonInitStruct.MultiTwoSamplingDelay= LL_ADC_MULTI_TWOSMP_DELAY_2CYCLES_5;
LL_ADC_CommonInit(__LL_ADC_COMMON_INSTANCE(ADC1), &ADC_CommonInitStruct);
/* Disable ADC deep power down (enabled by default after reset state) */
LL_ADC_DisableDeepPowerDown(ADC1);
/* Enable ADC internal voltage regulator */
LL_ADC_EnableInternalRegulator(ADC1);
/* Delay for ADC internal voltage regulator stabilization. */
/* Compute number of CPU cycles to wait for, from delay in us. */
/* Note: Variable divided by 2 to compensate partially */
/* CPU processing cycles (depends on compilation optimization). */
/* Note: If system core clock frequency is below 200kHz, wait time */
/* is only a few CPU processing cycles. */
__IO uint32_t wait_loop_index;
wait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
while(wait_loop_index != 0)
wait_loop_index--;
/** Configure Regular Channel
LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_4);
LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_4, LL_ADC_SAMPLINGTIME_1CYCLE_5);
LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_4, LL_ADC_SINGLE_ENDED);
/* USER CODE BEGIN ADC1_Init 2 */
LL_ADC_StartCalibration(ADC1,LL_ADC_CALIB_OFFSET,LL_ADC_SINGLE_ENDED);
//HAL_ADCEx_Calibration_Start(&hadc1,ADC_CALIB_OFFSET,ADC_SINGLE_ENDED); //ADC校验
/* USER CODE END ADC1_Init 2 */
/* ADC2 init function */
void MX_ADC2_Init(void)
/* USER CODE BEGIN ADC2_Init 0 */
/* USER CODE END ADC2_Init 0 */
LL_AHB4_GRP1_EnableClock(LL_AHB4_GRP1_PERIPH_GPIOB);
/**ADC2 GPIO Configuration
PB1 ------> ADC2_INP5
GPIO_InitStruct.Pin = LL_GPIO_PIN_1;
LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* USER CODE BEGIN ADC2_Init 1 */
/* USER CODE END ADC2_Init 1 */
/** Common config
LL_ADC_SetOverSamplingScope(ADC2, LL_ADC_OVS_DISABLE);
LL_ADC_Init(ADC2, &ADC_InitStruct);
LL_ADC_REG_Init(ADC2, &ADC_REG_InitStruct);
LL_ADC_DisableDeepPowerDown(ADC2);
LL_ADC_EnableInternalRegulator(ADC2);
wait_loop_index--;
LL_ADC_REG_SetSequencerRanks(ADC2, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_5);
LL_ADC_SetChannelSamplingTime(ADC2, LL_ADC_CHANNEL_5, LL_ADC_SAMPLINGTIME_1CYCLE_5);
LL_ADC_SetChannelSingleDiff(ADC2, LL_ADC_CHANNEL_5, LL_ADC_SINGLE_ENDED);
/* USER CODE BEGIN ADC2_Init 2 */
// HAL_ADCEx_Calibration_Start(&hadc2,ADC_CALIB_OFFSET,ADC_SINGLE_ENDED);
LL_ADC_StartCalibration(ADC2,LL_ADC_CALIB_OFFSET,LL_ADC_SINGLE_ENDED);
/* USER CODE END ADC2_Init 2 */
before is generated and below is added in main
LL_ADC_SetMultiDMATransfer(ADC12_COMMON,LL_ADC_MULTI_REG_DMA_EACH_ADC);
LL_DMA_SetDataLength(DMA1,LL_DMA_STREAM_4,4);
LL_DMA_ConfigAddresses(DMA1,LL_DMA_STREAM_4,(uint32_t)&(ADC12_COMMON->CDR),(uint32_t)&ADC_ConvertedValueDual[0],LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_ADC_Enable(ADC1);
LL_ADC_Enable(ADC2);
LL_ADC_EnableIT_OVR(ADC1);
LL_DMA_EnableIT_TC(DMA1,LL_DMA_STREAM_4);
LL_DMA_EnableBufferableTransfer(DMA1,LL_DMA_STREAM_4);
LL_DMA_EnableStream(DMA1,LL_DMA_STREAM_4);
expected behavior is the adc1/2 convert periodicly every 5cycles, and dma transfer data to &ADC_ConvertedValueDual[0]
then the DMA1_Stream4_IRQHandler() should've been triggered, however none of these are happened
if you have any suggestion please kindly reply
thx alot
Imen.D
Hello @mize ,
  1. I confirmed the 1st reported issue. For that, an internal ticket number 186541 is submitted in order to fix this.
  2. Did you check for transfer error interrupt?
How you configure and handle the DMA transfer complete interrupt ?
Did you start ADC conversions using LL_ADC_REG_StartConversion?
More details on the configuration of dual ADC mode and DMA provided in this section of RM0433.
Imen
3 REPLIES 3
Imen.D
Hello @mize ,
Please share your ioc file and the version used of CubeMx, this will help to reproduce the case.
Imen
HI,
   IOC file is attached, cubemx version is 6.12.0-RC9
   THX
   by the way any idea about my 2nd issue?
Imen.D
Hello @mize ,
Imen
