2024-11-15 11:16 PM - last edited on 2024-11-19 04:01 AM by Andrew Neil
How to solve this error 'error loading software packs run-time environment might work incorrectiy see build output for details' when using STM32H745?
Thank you!
2024-11-19 06:32 PM
Thank you all for reply.
I use KEIL and had already installed H7 pack. I have solved this problem by reinstalling KEIL and related packs.
I think there maybe some files damaged during operation.
2024-11-19 03:07 AM
Hello @Harry_Wan and welcome to the community,
To increase the probably of obtaining a answer, could you please share your project and more details about "build output"?
Thank you.
Kaouthar
2024-11-19 03:31 AM
@Harry_Wan wrote:see build output for details'
So did you do that?
@Harry_Wan wrote:when using STM32H745?
A bit more detail there would help: what exactly were you doing? What were the steps to get to this situation?
Is this in STM32CubeIDE?
2024-11-19 05:05 AM
Sounds like KEIL/MDK
What Version? What version of H7 Pack?
2024-11-19 05:06 AM - edited 2024-11-19 05:07 AM
If KEIL used, did you already installed the H7 pack? from: https://www.keil.arm.com/packs/stm32h7xx_dfp-keil/overview/
2024-11-19 06:32 PM
2024-11-20 12:39 AM
Always important to say what tools you're using - especially in a post about your tools!
Now it's fixed, please mark the solution:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
