ARM CMSIS DSP for CubeMX and Keil
‎2025-03-04 1:52 AM
Hi everyone;
I have select;
In cube mx ->
middleware and software packs -> CMSIS -> CMSIS Core
middleware and software packs -> CMSIS - DSP
middleware and software packs -> X Cube Algobuild -> DSP Library
Later, I have select from software packs -> select components -> ARM.CMSIS 6.1.0 -> CMSIS Core and CMSIS DSP Source and X cube algobuild DSP Library.
In keil, manage run time environment ı have select core and dsp source there is no dsp library and i have 991 errors for dsp library.
Could you help me please, thank's a lot.
- Labels:
STM32CubeMX
STM32F4 Series
‎2025-03-04 2:53 AM
All of final version, I solve the problem below;
1) One time generate code from CubeMx and build in keil
2) Close keil
3) Re-generate from cubeMx
‎2025-03-04 2:36 AM
Hello @CKILI.2;
To check the issue could you give more details:
- Which versions of STM32CubeMx and Keil are you using?
- Could you please share your .ioc file?
- What errors do you get?
If you use STM32CubeIDE, do you have the same errors?
These articles can help you to integrate DSP libraries on STM32CubeIDE:
- Configuring DSP libraries on STM32CubeIDE - STMicroelectronics Community
- How to integrate CMSIS-DSP libraries on a STM32 project - STMicroelectronics Community
Thank you.
Kaouthar
‎2025-03-04 2:53 AM
2) Close keil
