STM32F429 timer Question
‎2025-01-18 9:29 PM - last edited on ‎2025-01-20 12:51 AM by mƎALLEm
im confused about the TIMPRE bit in the RCC_DCKCFGR does it only effect the apb1 and not apb2 timers cause the way it describes this bit it acts like the apb2 can be times 4 because it says PPREx so 1 or 2 but on cube mx im noticing when u enable the timer prescaler the only timers effected are the apb1 timers
- Labels:
STM32F4 Series
TIM
‎2025-01-20 5:46 AM
The Reference Manual (RM) is more authoritative than CubeMX.
I don't use CubeMX. Show how RCC_DCKCFGR.TIMPRE is set in CubeMX and how that does/does not affect the timer clocks.
‎2025-01-20 5:49 AM
Hello @Franksterb92,
This explanation is based on RM description:
if TIMPRE = 0:
- If the APB prescaler (PPRE1, PPRE2 in the RCC_CFGR register) is configured to a division factor of 1, then TIMxCLK = PCLKx
- Otherwise, the timer clock frequencies are set to twice the frequency of the APB domain to which the timers are connected: TIMxCLK = 2xPCLKx
if TIMPRE = 1:
- If the APB prescaler (PPRE1, PPRE2 in the RCC_CFGR register) is configured to a division factor of 1, 2, or 4, then TIMxCLK = HCLK
- Otherwise, the timer clock frequencies are set to four times the frequency of the APB domain to which the timers are connected: TIMxCLK = 4xPCLKx
Could you describe a concrete use case where you are noticing that only APB1 timers are affected?
‎2025-01-20 1:06 PM
it just confusing that it says that apb2 can be 4 times which would be 360mhz if hclk == 168mhz ... see what im saying
‎2025-01-20 2:11 PM
Yeah, I'm hard pressed to see it doing that too.
The PLL usually has a DIV2 out of the VCO, because it's a pulse-generator, and all the logic for the MCU/Peripheral are predicated on a 50/50 duty clock.
I think what's trying to be communicated is that if the APB is divided down the TIM can be faster, by skipping dividers in the HCLK/SYSCLK chains, not that it's actually multiplying anything.
Can be 168 MHz, not 336 MHz (or 180/360 for the higher clocking option), when the APBx is 42 MHz
