STM32C0 with 5V power as in AN392
Miyuki
I am a little confused here, AN392 claims to run STM32C0 from a 5V power supply, directly from the main fed RCD dropper with a 5.6V Zener. But the datasheet says the maximum voltage is 4V.
So does the AN suggest running way over max specs or is there something I miss?
SofLit
Issue fixed in AN392 Rev 4 / figure 2.
4 REPLIES 4
SofLit
Good catch. Need to check this internally.
You mean this?
SofLit
Internal ticket 178788 has been created to fix this. The ticket is not accessible by the community users.
SofLit
