PWM DMA settings
‎2023-09-29 2:04 AM
Hi there, i am using STM32F401RE development board and using PWM generation using DMA. I am following register level programming approach and here the issue lies in the DMA settings. Like if I set my PSIZE and MSIZE to 32-bit long and also if my data_buffer is "uint32_t" then and then only the proper wave generation is happening. If I change either the DMA setting to a half-word or a byte OR even if I change the buffer data type to "utin16_t or uint8_t", it is corrupting my entire waveform. Any specific reason for this?
Note: I am using PLL 72MHz as core frequency. Does it have any effect on it. I am using DMA_1 Stream 5, Timer 2, Channel 1.
Also how much impact does the xSIZE selection (PSIZE and MSIZE selection) have on the code?
- Labels:
STM32F4 Series
‎2023-09-29 2:38 AM
Isn't Timer 2 a 32 bit timer? Then why would you use anything but 32 bit values?
‎2023-09-29 2:49 AM
Okay that i got it but the thing is what if i use byte as the MSIZE and PSIZE, it should work right?
‎2023-09-29 5:51 AM
Probably not, unless all the values you are writing are meant to be 8 bits. Why would it work?
It fundamentally changes the operation. Perhaps focus on what the value should be and choose the correct size appropriately.
‎2023-09-29 6:55 AM
Hello @DJ1
The data width of the number of data items to transfer is configured in the DMA_SxNDTR register which is equal to the width of the peripheral bus (configured by the PSIZE bits in the DMA_SxCR register).
Check the reference manual section 9.3.10 Programmable data width, packing/unpacking, endianess
‎2023-09-29 7:49 AM
As @FBL said above, this implies that PSIZE *must* be set to 32-bit.
If you don't use DMA FIFO (i.e. use "direct mode"), then MSIZE is ignored and the memory-size width is forced to be identical to PSIZE. If you use FIFO, the data packing feature won't help you to reduce memory buffer size anyway, there are always 4 bytes picked at memory side for one word write on peripheral side.(The latter is in contrast with the single-port DMAs in the lower-end STM32s, where in case of MSIZE<PSIZE the rest is zero-extended).
