Package UFQFPN32 (5x5 mm) for STM32F302x6 STM32F302x8
‎2020-02-03 8:58 AM
The package UFQFPN32 (5x5 mm) have an exposed pad but where is the definition of this Exposed Pad in the datasheet for the STM32F302K8 K Must I connect to the GND or is it not connected or maybe another pin definition ? I can't see in the datasheet.
Thanks for your help.
Documentation
STM32F3 Series
‎2020-02-17 6:59 AM
Hello @ATrem.1​ and @Community member​ ,
Indeed the note to be added is the following: "“There is an exposed die pad on the underside of the UFQFPN package. It is recommended to connect and solder this back-side pad to PCB ground".
We need to wait for new document release to add it.
Thanks,
Amel
‎2020-02-03 2:39 PM
This is a recurring question, see e.g. https://community.st.com/s/question/0D50X00009XkZOtSAN/stm32f301k8u6-connection-of-exposed-pad , https://community.st.com/s/question/0D50X00009XkWZWSA3/stm32f301kxux-exposed-pad-of-ufqfpn-package-connection , https://community.st.com/s/question/0D50X00009XkX5mSAF/stm32l071kbux-ufqfpn32-exposed-pad .
I can't find the mentioned remark in DocID025147 rev.7 (STM32F302x6 STM32F302x8 DS) nor in DS9895 Rev 8 (STM32F301x6 STM32F301x8).
@Amel NASRI​ , could this please be resolved, possibly for all the relevant DS with packages which have exposed pad?
‎2020-02-17 6:59 AM
Thanks,
Amel
‎2020-02-17 8:29 AM
Thanks, Amel.
‎2020-02-17 8:48 AM
Thanks, Amel.
So it's the same for a lot of STM32 references with the same package. The STM32L432KC is in this case ?
‎2020-02-18 5:23 AM
Need to check for STM32L432KC.
‎2020-03-13 2:09 AM
For my board, I connected it to the GND and it's working. I hope no problem later...
‎2020-05-06 3:32 AM
Note added for F302 datasheet (https://www.st.com/resource/en/datasheet/stm32f302r6.pdf).
‎2020-05-06 2:13 PM
Thanks, Amel.
‎2021-09-03 4:40 AM
