Measuring Ground current does not seem to match datasheet on STM32L476RG (Nucleo-L476RG)?
‎2024-09-01 2:22 PM
Hello...
I am using a Nucleo-L476RG dev board along with https://github.com/STMicroelectronics/STM32CubeL4 . I have built the code for PWR_STOP1_RTC and am trying to measure ground current. I have a 10 ohm resistor on the ground side of 3.2V battery. I have removed JP6 and JP5 on the board. I am using a USB PicoScope. At the moment I have two issues:
1. I load the FW onto the target but I don't understand why this FW does NOT seem to run if I don't keep the usb connected to the nucleo? Why is this? I would like to disconnect this as it is just a source of noise and I am getting no where near the approx. 4 uA - 20 uA the datasheet specifies.
2. For some reason the ground current (when 1. above is connected) measures negative? I can plug into a traditional scope and it is not negative. I did calibrate probe and when connected to picoscope I did the autozero...Any thoughts here?
STM32L4 Series
‎2024-09-05 3:19 AM - edited ‎2024-09-05 3:37 AM
@SWenn.1 wrote:this FW does NOT seem to run if I don't keep the usb connected to the nucleo? Why is this?
In addition to the unpowered ST-Link holding NRST low, as @Sarra.S mentioned, note that the MCU clock source on most* Nucleo boards defaults to the ST-Link - have you taken that into account?
On the NRST thing:
EDIT:
* It seems that the Nucleo-L476RG is an exception:
‎2024-09-05 3:00 AM
Hello @SWenn.1,
Try probing the NRST pin, this could happen if the NRST line is being held low by the ST-Link when the USB is disconnected
2nd issue is probably related to probe calibration since it's not negative using an oscilloscope
On the NRST thing:
EDIT:
‎2024-09-05 3:33 AM - edited ‎2024-09-05 3:34 AM
@SWenn.1 wrote:I have removed JP6
JP6 is the Idd measuring link - when you remove that, you disconnect power from the Target MCU.
The idea is that you insert a current meter here to measure the Target MCU's current consumption:
‎2024-09-05 7:37 AM
@Sarra.S ...Thank you ...that worked with using a pullup to VDD.
‎2024-09-05 7:50 AM
don't forget to mark the solution:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
‎2024-09-05 11:05 AM
Just a quick follow up for documentation purposes and others....
To get a good clean measurement on ground current using a scope and a ground resistor I had to:
connect a resistor between NRST and VDD as a pullup
I also had to remove the 0 ohm resistor labeled SB12 NRST. This was critical as somehow the 3V3_ST_LINK net had 2.5V on it even without USB connection and JP6 not connected. It was feeding back thru somewhere and causing the STLINK chip to have power.
‎2024-09-05 11:38 AM - edited ‎2024-09-05 6:58 PM
@SWenn.1 wrote:To get a good clean measurement on ground current using a scope and a ground resistor I had to:
That's odd, given that it has an internal pull-up.
If something was indeed holding the NRST low, it would make more sense to stop that from happening, rather then add a pullup to fight it. Otherwise, it's like turning on a space-heater instead of turning off the A/C. I'm not sure adding a pullup is enough to skew your measurements, but it definitely won't help.
- Please post an update with details once you've solved your issue. Your experience may help others.
