Keil Debug
Charlie CHEN
Hi professor,
I`m trying to use debug mode with keil.I get it in to the function and it run the function without press run button,but when I stop it ,it go in to hardfault.
Is any one have faced the problem before?
4 REPLIES 4
SystemInit faults? Perhaps step in to that and review the code. Inspect Hard Fault location reported by processor, it has registers for that.
Are you using RAM which needs a clock enabled?
Hi @Community member​ ,
Thanks for your reply!
I have enabled the appropriate clock ,and I cannot check the register cause it can`t run normally,just stuck in Reset_Handler.
Is there any problem occur?
Thanks again!
Use Stop to see where it is.
Turn off the "Run to main()" setting of the debugger, and start stepping into/through the SystemInit() function. Determine where things go wrong, and where exactly it ends up.
@Community member​
Thanks for your helping!
I found out where the wrong is,and solved it.
Really appreciate your patient and advice!:thumbs_up:
