Interrupt not triggered on EXTI1
‎2023-05-04 12:47 AM
actually I'm using stm32F446RE, I'm using hal library just to detect external interrupt from PA1 pin but it doesn't work, and if I put the interrupt from PA0 pin, it works fine?
/* USER CODE BEGIN 0 */
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
count++;
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_TIM1_Init();
while (1)
void MX_GPIO_Init(void)
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin : PA1 */
GPIO_InitStruct.Pin = GPIO_PIN_1;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
/* EXTI interrupt init*/
HAL_NVIC_SetPriority(EXTI1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(EXTI1_IRQn);
GPIO-EXTI
Interrupt
STM32F4 Series
‎2023-05-04 1:54 AM
thx for your answers @Sarra.S​ @Community member​ , i just replaced the stm card and it works
the pb that the pin PA1 is burnt
‎2023-05-04 1:26 AM
Hello @kkhli.1​,
Check that the EXTI1_IRQ interrupt is not being masked by other interrupts with higher priorities
‎2023-05-04 1:30 AM - edited ‎2023-11-20 6:30 AM
hello ,i'm using only one interrupt
‎2023-05-04 1:38 AM
Make sure you have connection from physical PA1 pin to the point you think the signal is. Observe input in GPIOA_IDR, or set PA1 as output and toggle.
Read out and check EXTI and relevant GPIO and SYSCFG registers content.
Other than that, follow the usual "interrupt does not fire" checklist.
‎2023-05-04 1:54 AM
