Internal Pull up STM32G4 series
‎2025-02-03 11:26 PM
I am using the internal pull up for the input pins, but when read the port status using the program, it always reads 0 instead of 1. I expected it to read 1 and if make that pin grounded it shall read 0.
STM32G4 Series
‎2025-02-04 3:28 AM
Yes I think the problem should be solved if you remove that 4K resistor
‎2025-02-04 3:29 AM
I can see 5 problems with the "existing" version and 3 with the new one. In the schematic they are labeled as R and C. Remove all of them and you circuit will work.
‎2025-02-04 4:29 AM
I would say, check the datasheet of your MCU for the value range of the internal pull-ups, and check it through.
I see nothing wrong with reading a 0-value for an unactuated switch. You could just drop the pull-up configuration, as it is most probably pointless in this situation.
I think the aim of the whole exercise is to differ between actuated switch state (1) and unactuated switch state (0).
And that does most probably work.
- « Previous
- 1
- 2
- Next »
