Hello ! I'm working on STM32L4 family and I want to use CAN filter to avoid a lot of message which are not for me. I need to filter only on bits [26:23] in ExtID. I read a lot of topic on this forum but I don't find the answer .... Thanks :)
MDami.3
7 REPLIES 7
So a comprehension problem?
The register represents a bit pattern as seen on the wire, you mask the things of interest, and those flagging a particular state vs others, and after you've masked the bits you compare that to a pattern.
Typically with Extended ID you need to be looking at the IDE flag to know it's this vs something else.
https://community.st.com/s/question/0D50X0000BedK8USQU/how-to-use-the-stm32f205-canbus-id-filter-it-seems-like-it-does-not-works-as-rule
MDami.3
Thanks for your quick answer !
I understand than using IDE flag can filter all EXTID right ? Can I filter all message with EXTID[26:23] set to 0x1 ?
In my confitguration I use :
   sFilterConfig.FilterMaskIdHigh = 0x07C0 ;
   sFilterConfig.FilterMaskIdLow = 0x0000 ;
   sFilterConfig.FilterIdHigh    = 0x0080 ;
   sFilterConfig.FilterIdLow     = 0x0000 ;
I prettry sure I miss something ...
Thanks again for reading me
Try
sFilterConfig.FilterMaskIdHigh = 0x3C00;
sFilterConfig.FilterMaskIdLow = 0x0004;
sFilterConfig.FilterIdHigh    = 0x0400;
sFilterConfig.FilterIdLow     = 0x0004;
MDami.3
Hello
Thanks for your answer and sorry for delay I wasn't available. I tried what you proposed and it's almost work but I miss some message ... I don't understand why to be honest .
MDami.3
For example, with your configuration I catch header 0x8d0104 but I miss 0x8d0084
In order to debug/understand why you'd need to dump the CAN reception data, and analyze that, and why the patterns fit or not.
Perhaps get a digest of ALL the extended messages, making sure you see the one you're looking for.
sFilterConfig.FilterMaskIdHigh = 0x0000;
sFilterConfig.FilterIdHigh    = 0x0000;
If you've got some register data I can look that over, but not going to work/test this independently.
