H7 OCTOSPI HyperRAM data throughput changing with compilation
‎2024-10-16 12:52 AM
Heyho,
I'm using the H733 (custom board) / H735 (eval kit) with Infineon's HyperRAM S70KL1281 / S70KL1282 at 100 MHz for some time now, all working great, except for one thing that is very annoying:
- the data throughput from / to HyperRAM seems to depend on compilation, even though the OCTOSPI peripheral was not changed
- after some compilations it's about 178 Mbyte / s, after another only 54 MB/s.
- data throughput is constant for one compilation, no matter if I call the test function at MCU power up or while operating with all other peripherals running
- no caching anywhere
I'm pretty sure that it's not "faulty" timing measurements, using the cycle counter and disabling all interrupt calls around the for loops.
- Is there something wrong in my test function?
- Is it maybe "only" how the for loop / iteration is compiled?
- right now I can't get it back to the high speed, so no map / list file
- my scope here is too old and slow to check the signal lines
Here's the test function, first writing to HyperRAM, then reading:
/* OCTOSPI HyperRAM test
#define HYPER_TEST_UART 1
uint32_t OspiHypRamTest(uint8_t u8CountDown)
uint32_t i = 0;
uint32_t u32Val = 0xFFFFFFFF;
uint32_t u32MaxLen = (uint32_t)((uint32_t)OSPI_HYPERRAM_END_ADDR / 4);
uint32_t u32Errors = 0;
uint32_t u32Data = 0;
uint32_t u32CycStart = 0;
uint32_t u32Cycles = 0;
float flClockMHz = (float)HAL_RCC_GetSysClockFreq() / 1E6;
float flVal = 0.0f;
uint32_t *pu32MemAddr = NULL;
if( OCTOSPI1 == pOspiHypRam ) pu32MemAddr = (uint32_t *)OCTOSPI1_BASE;
else if( OCTOSPI2 == pOspiHypRam ) pu32MemAddr = (uint32_t *)OCTOSPI2_BASE;
#if HYPER_TEST_UART
uart_printf("\n\r+++++++++++++++++++++++++++++++++++++++++++++++++\n\r");
uart_printf("OCTOSPI HyperRAM test, memory mapped, IRQs OFF\n\rcounting ");
if( 0 == u8CountDown ) uart_printf("UP, start with 0\n\r\n\r");
else uart_printf("DOWN, start with %08lX\n\r\n\r", u32Val);
uart_printf("writing bytes: %lu\n\r", (uint32_t)OSPI_HYPERRAM_END_ADDR);
#endif
__DSB();
__disable_irq();
/* write complete HyperRAM */
/* UP - should be faster */
u32CycStart = DWT->CYCCNT;
for( i = 0; i < u32MaxLen; i++ )
pu32MemAddr[i] = i;
__DMB();
__DSB();
u32Cycles = DWT->CYCCNT;
/* DOWN */
else
pu32MemAddr[i] = u32Val;
u32Val--;
__DMB();
__DSB();
__enable_irq();
__DSB();
u32Cycles -= u32CycStart;
flVal = (float)u32Cycles / flClockMHz;
flOspiRamSpeedMBpsMmWr = (float)OSPI_HYPERRAM_END_ADDR / flVal;
flOspiRamSpeedMBpsMmWr *= (float)MEGA_CORRECTION;
#if HYPER_TEST_UART
uart_printf("%lu CPU cycles = %.1f ms\n\r", u32Cycles, (flVal / 1000.0f));
uart_printf("\n\r-> %.2f MB/s (%.0f Mbit/s) WRITE\n\r\n\r", flOspiRamSpeedMBpsMmWr, (8.0f * flOspiRamSpeedMBpsMmWr));
uart_printf("reading & comparing bytes: %lu\n\r", (uint32_t)OSPI_HYPERRAM_END_ADDR);
#endif
__DSB();
__disable_irq();
__DSB();
/* read complete HyperRAM and compare */
u32Data = pu32MemAddr[i];
if( u32Data != i ) u32Errors++;
__DMB();
__DSB();
/* DOWN */
else
if( u32Data != (u32Val - i) ) u32Errors++;
__DMB();
__DSB();
__enable_irq();
flOspiRamSpeedMBpsMmRd = (float)OSPI_HYPERRAM_END_ADDR / flVal;
flOspiRamSpeedMBpsMmRd *= (float)MEGA_CORRECTION;
#if HYPER_TEST_UART
uart_printf("\n\r-> %.2f MB/s (%.0f Mbit/s) READ\n\r", flOspiRamSpeedMBpsMmRd, (8.0f * flOspiRamSpeedMBpsMmRd));
if( 0 == u32Errors ) uart_printf("\n\rNULL errors\n\r");
else uart_printf("\n\r# ERR: u32Errors = %lu\n\r", u32Errors);
uart_printf("-------------------------------------------------\n\r");
#endif
return u32Errors;
Anybody any ideas?
Thanks in advance!
OctoSPI
STM32H7 Series
‎2024-10-18 9:29 AM
Dear @LCE ,
this is a follow-up can you change all of your variables and buffer of data to have 64-bits wide instead of a word by this
uint64_t instead of uint32_t
and let us know if now the compilation is stable . The idea is to use maximum optimized width for the AXI bus where the OctoSPI is connected.
Hope it helps ,
STOne-32
‎2024-10-20 11:57 PM
Hello @STOne-32 ,
thanks for taking a look at this!
So, right now I get these results:
counting UP:
Read = 144.61 MB/s
Write = 58.69 MB/s for( i = 0; i < u32MaxLen; i++ ) pu32MemAddr[i] = i;
counting DOWN:
Read = 54.50 MB/s
Write = 179.32 MB/s
I would have expected the results to be the other way round...
Because Write UP is simply: for( i = 0; i < u32MaxLen; i++ ) pu32MemAddr[i] = i;
And in the list file that's only 4 lines of assembler (also only 4 lines for write DOWN)
Here's the list file part with the function OspiHypRamTest(uint8_t u8CountDown)
080523b0 <OspiHypRamTest>:
80523b0: b538 push {r3, r4, r5, lr}
80523b2: 4604 mov r4, r0
80523b4: f01d fa74 bl 806f8a0 <HAL_RCC_GetSysClockFreq>
80523b8: ee07 0a90 vmov s15, r0
80523bc: 4d4c ldr r5, [pc, #304] ; (80524f0 <OspiHypRamTest+0x140>)
80523be: 4a4d ldr r2, [pc, #308] ; (80524f4 <OspiHypRamTest+0x144>)
80523c0: eeb8 7a67 vcvt.f32.u32 s14, s15
80523c4: 682b ldr r3, [r5, #0]
80523c6: ed9f 6b48 vldr d6, [pc, #288] ; 80524e8 <OspiHypRamTest+0x138>
80523ca: eeb7 7ac7 vcvt.f64.f32 d7, s14
80523ce: 4293 cmp r3, r2
80523d0: ee27 7b06 vmul.f64 d7, d7, d6
80523d4: eeb7 7bc7 vcvt.f32.f64 s14, d7
80523d8: d07f beq.n 80524da <OspiHypRamTest+0x12a> ; load address of OCTOSPI 1
80523da: f502 42a0 add.w r2, r2, #20480 ; 0x5000
80523de: 4293 cmp r3, r2
80523e0: bf0c ite eq
80523e2: f04f 42e0 moveq.w r2, #1879048192 ; 0x70000000 OCTOSPI 2 unused
80523e6: 2200 movne r2, #0
80523e8: f3bf 8f4f dsb sy
; WRITE loops in between cpsid / cpsie
80523ec: b672 cpsid i
80523ee: 4b42 ldr r3, [pc, #264] ; (80524f8 <OspiHypRamTest+0x148>) DWT->CYCCNT
80523f0: 3a04 subs r2, #4
80523f2: 6858 ldr r0, [r3, #4]
80523f4: 4611 mov r1, r2
80523f6: 2c00 cmp r4, #0
80523f8: d165 bne.n 80524c6 <OspiHypRamTest+0x116> ; u8CountDown != 0, jump to write DOWN
80523fa: 4623 mov r3, r4
; write UP loop
80523fc: f841 3f04 str.w r3, [r1, #4]!
8052400: 3301 adds r3, #1
8052402: f5b3 0f80 cmp.w r3, #4194304 ; 0x400000 memory size in 32b
8052406: d1f9 bne.n 80523fc <OspiHypRamTest+0x4c>
8052408: f3bf 8f5f dmb sy
805240c: f3bf 8f4f dsb sy
8052410: 4b39 ldr r3, [pc, #228] ; (80524f8 <OspiHypRamTest+0x148>) DWT->CYCCNT
8052412: 685b ldr r3, [r3, #4]
8052414: b662 cpsie i
; WRITE end
8052416: f3bf 8f4f dsb sy
805241a: 1a1b subs r3, r3, r0
805241c: ed9f 6a37 vldr s12, [pc, #220] ; 80524fc <OspiHypRamTest+0x14c>
8052420: eddf 6a37 vldr s13, [pc, #220] ; 8052500 <OspiHypRamTest+0x150>
8052424: ee07 3a90 vmov s15, r3
8052428: 4936 ldr r1, [pc, #216] ; (8052504 <OspiHypRamTest+0x154>)
805242a: ee27 7a26 vmul.f32 s14, s14, s13
805242e: eef8 7a67 vcvt.f32.u32 s15, s15
8052432: eec6 6a27 vdiv.f32 s13, s12, s15
8052436: ee66 7a87 vmul.f32 s15, s13, s14
805243a: edc1 7a00 vstr s15, [r1]
805243e: f3bf 8f4f dsb sy
8052442: 492c ldr r1, [pc, #176] ; (80524f4 <OspiHypRamTest+0x144>)
8052444: 682b ldr r3, [r5, #0]
8052446: 428b cmp r3, r1
8052448: d04a beq.n 80524e0 <OspiHypRamTest+0x130>
805244a: 482f ldr r0, [pc, #188] ; (8052508 <OspiHypRamTest+0x158>)
805244c: 492f ldr r1, [pc, #188] ; (805250c <OspiHypRamTest+0x15c>)
805244e: 4283 cmp r3, r0
8052450: bf08 it eq
8052452: 460a moveq r2, r1
; READ & compare loops in between cpsid / cpsie
8052454: b672 cpsid i
8052456: f3bf 8f4f dsb sy
805245a: bb1c cbnz r4, 80524a4 <OspiHypRamTest+0xf4> ; u8CountDown != 0, jump to read DOWN
805245c: 4b26 ldr r3, [pc, #152] ; (80524f8 <OspiHypRamTest+0x148>) DWT->CYCCNT
805245e: 4620 mov r0, r4
8052460: 685c ldr r4, [r3, #4]
8052462: 4603 mov r3, r0
; read & compare UP loop
8052464: f852 1f04 ldr.w r1, [r2, #4]!
8052468: 4299 cmp r1, r3
805246a: f103 0301 add.w r3, r3, #1
805246e: bf18 it ne
8052470: 3001 addne r0, #1
8052472: f5b3 0f80 cmp.w r3, #4194304 ; 0x400000 memory size in 32b
8052476: d1f5 bne.n 8052464 <OspiHypRamTest+0xb4>
8052478: f3bf 8f5f dmb sy
805247c: f3bf 8f4f dsb sy
8052480: 4b1d ldr r3, [pc, #116] ; (80524f8 <OspiHypRamTest+0x148>) DWT->CYCCNT
8052482: 685b ldr r3, [r3, #4]
8052484: b662 cpsie i
; READ & compare end
8052486: 1b1b subs r3, r3, r4
8052488: ed9f 6a1c vldr s12, [pc, #112] ; 80524fc <OspiHypRamTest+0x14c>
805248c: 4a20 ldr r2, [pc, #128] ; (8052510 <OspiHypRamTest+0x160>)
805248e: ee07 3a90 vmov s15, r3
8052492: eef8 7a67 vcvt.f32.u32 s15, s15
8052496: eec6 6a27 vdiv.f32 s13, s12, s15
805249a: ee26 7a87 vmul.f32 s14, s13, s14
805249e: ed82 7a00 vstr s14, [r2]
80524a2: bd38 pop {r3, r4, r5, pc}
; read & compare prepare
80524a4: 4914 ldr r1, [pc, #80] ; (80524f8 <OspiHypRamTest+0x148>) DWT->CYCCNT
80524a6: f04f 33ff mov.w r3, #4294967295 ; 0xFFFFFFFF
80524aa: 2000 movs r0, #0
80524ac: f46f 0c80 mvn.w ip, #4194304 ; 0x400000 memory size in 32b
80524b0: 684c ldr r4, [r1, #4]
; read & compare DOWN loop
80524b2: f852 1f04 ldr.w r1, [r2, #4]!
80524b6: 4299 cmp r1, r3
80524b8: f103 33ff add.w r3, r3, #4294967295 ; 0xFFFFFFFF
80524bc: bf18 it ne
80524be: 3001 addne r0, #1
80524c0: 4563 cmp r3, ip
80524c2: d1f6 bne.n 80524b2 <OspiHypRamTest+0x102>
80524c4: e7d8 b.n 8052478 <OspiHypRamTest+0xc8> ; back to end of read
80524c6: f04f 33ff mov.w r3, #4294967295 ; 0xFFFFFFFF
80524ca: f46f 0c80 mvn.w ip, #4194304 ; 0x400000 memory size in 32b
; write DOWN loop
80524ce: f841 3f04 str.w r3, [r1, #4]!
80524d2: 3b01 subs r3, #1
80524d4: 4563 cmp r3, ip
80524d6: d1fa bne.n 80524ce <OspiHypRamTest+0x11e>
80524d8: e796 b.n 8052408 <OspiHypRamTest+0x58> ; back to end of write
80524da: f04f 4210 mov.w r2, #2415919104 ; 0x90000000 OCTOSPI 1 with HyperRAM
80524de: e783 b.n 80523e8 <OspiHypRamTest+0x38> ; back
80524e0: 4a0c ldr r2, [pc, #48] ; (8052514 <OspiHypRamTest+0x164>)
80524e2: e7b7 b.n 8052454 <OspiHypRamTest+0xa4> ; back to 1st loop
80524e4: f3af 8000 nop.w
80524e8: a0b5ed8d .word 0xa0b5ed8d
80524ec: 3eb0c6f7 .word 0x3eb0c6f7
80524f0: 24002cbc .word 0x24002cbc
80524f4: 52005000 .word 0x52005000
80524f8: e0001000 .word 0xe0001000
80524fc: 4b800000 .word 0x4b800000
8052500: 3f742400 .word 0x3f742400
8052504: 24002bfc .word 0x24002bfc
8052508: 5200a000 .word 0x5200a000
805250c: 6ffffffc .word 0x6ffffffc
8052510: 24002bf8 .word 0x24002bf8
8052514: 8ffffffc .word 0x8ffffffc
‎2024-10-20 11:58 PM
... including some comments.
I didn't find the option to select "assembler" for source code posting.
‎2024-10-21 12:29 AM
I just found that I had set the alignment of the HyperRAM in the linker filer to "ALIGN(8)" = 64 bit.
I changed it to ALIGN(4) - and it didn't change anything.
‎2024-10-21 12:32 AM
so here are the results of the 64 bit version (including ALIGN(8) in .ld):
HyperRAM speed:
UP:
Read = 113.10 MB/s
Write = 117.38 MB/s
DOWN:
Read = 105.42 MB/s
Write = 179.32 MB/s
/* 64 bit version */
uint64_t i = 0;
uint64_t u64Val = 0xFFFFFFFF;
uint64_t u64MaxLen = (uint64_t)((uint64_t)OSPI_HYPERRAM_END_ADDR / 8);
uint64_t u64Data = 0;
uint64_t *pu64MemAddr = NULL;
float flVal = 0.0f;
if( OCTOSPI1 == pOspiHypRam ) pu64MemAddr = (uint64_t *)OCTOSPI1_BASE;
else if( OCTOSPI2 == pOspiHypRam ) pu64MemAddr = (uint64_t *)OCTOSPI2_BASE;
/* WRITE complete HyperRAM */
__DSB();
__disable_irq();
for( i = 0; i < u64MaxLen; i++ )
pu64MemAddr[i] = i;
/* DOWN */
else
pu64MemAddr[i] = u64Val;
u64Val--;
__DMB();
__DSB();
__enable_irq();
__DSB();
/* WRITE speed calculation */
__DSB();
/* READ & CHECK */
__disable_irq();
__DSB();
u64Data = pu64MemAddr[i];
if( u64Data != i ) u32Errors++;
/* DOWN */
else
if( u64Data != (u64Val - i) ) u32Errors++;
__DMB();
__DSB();
__enable_irq();
/* READ speed calculation */
‎2024-10-21 12:33 AM
And here's the list file:
80523b0: b5f8 push {r3, r4, r5, r6, r7, lr}
80523b2: 4605 mov r5, r0
80523b4: f01d fa94 bl 806f8e0 <HAL_RCC_GetSysClockFreq>
80523bc: 4e5c ldr r6, [pc, #368] ; (8052530 <OspiHypRamTest+0x180>)
80523be: 4a5d ldr r2, [pc, #372] ; (8052534 <OspiHypRamTest+0x184>)
80523c4: 6833 ldr r3, [r6, #0]
80523c6: ed9f 6b58 vldr d6, [pc, #352] ; 8052528 <OspiHypRamTest+0x178>
80523d8: f000 809f beq.w 805251a <OspiHypRamTest+0x16a>
80523dc: 4956 ldr r1, [pc, #344] ; (8052538 <OspiHypRamTest+0x188>)
80523de: 428b cmp r3, r1
80523e2: f04f 41e0 moveq.w r1, #1879048192 ; 0x70000000
80523e6: 2100 movne r1, #0
80523ee: 4b53 ldr r3, [pc, #332] ; (805253c <OspiHypRamTest+0x18c>)
80523f0: 3908 subs r1, #8
80523f2: 685f ldr r7, [r3, #4]
80523f4: 468c mov ip, r1
80523f6: 2d00 cmp r5, #0
80523f8: d17c bne.n 80524f4 <OspiHypRamTest+0x144>
80523fa: 462b mov r3, r5
80523fc: 462a mov r2, r5
80523fe: 1c5c adds r4, r3, #1
8052400: f84c 3f08 str.w r3, [ip, #8]!
8052404: f8cc 2004 str.w r2, [ip, #4]
8052408: 4623 mov r3, r4
805240a: f142 0200 adc.w r2, r2, #0
805240e: f5a4 1400 sub.w r4, r4, #2097152 ; 0x200000
8052412: ea54 0002 orrs.w r0, r4, r2
8052416: d1f2 bne.n 80523fe <OspiHypRamTest+0x4e>
8052418: f3bf 8f5f dmb sy
805241c: f3bf 8f4f dsb sy
8052420: 4b46 ldr r3, [pc, #280] ; (805253c <OspiHypRamTest+0x18c>)
8052422: 685b ldr r3, [r3, #4]
8052424: b662 cpsie i
8052426: f3bf 8f4f dsb sy
805242a: 1bdb subs r3, r3, r7
805242c: ed9f 6a44 vldr s12, [pc, #272] ; 8052540 <OspiHypRamTest+0x190>
8052430: eddf 6a44 vldr s13, [pc, #272] ; 8052544 <OspiHypRamTest+0x194>
8052434: ee07 3a90 vmov s15, r3
8052438: 4a43 ldr r2, [pc, #268] ; (8052548 <OspiHypRamTest+0x198>)
805243a: ee27 7a26 vmul.f32 s14, s14, s13
805243e: eef8 7a67 vcvt.f32.u32 s15, s15
8052442: eec6 6a27 vdiv.f32 s13, s12, s15
8052446: ee66 7a87 vmul.f32 s15, s13, s14
805244a: edc2 7a00 vstr s15, [r2]
805244e: f3bf 8f4f dsb sy
8052452: 4a38 ldr r2, [pc, #224] ; (8052534 <OspiHypRamTest+0x184>)
8052454: 6833 ldr r3, [r6, #0]
8052456: 4293 cmp r3, r2
8052458: d062 beq.n 8052520 <OspiHypRamTest+0x170>
805245a: f502 42a0 add.w r2, r2, #20480 ; 0x5000
805245e: 483b ldr r0, [pc, #236] ; (805254c <OspiHypRamTest+0x19c>)
8052460: 4293 cmp r3, r2
8052462: bf08 it eq
8052464: 4601 moveq r1, r0
8052466: b672 cpsid i
8052468: f3bf 8f4f dsb sy
805246c: bb4d cbnz r5, 80524c2 <OspiHypRamTest+0x112>
805246e: 4628 mov r0, r5
8052470: 4b32 ldr r3, [pc, #200] ; (805253c <OspiHypRamTest+0x18c>)
8052472: 4602 mov r2, r0
8052474: 685d ldr r5, [r3, #4]
8052476: 4603 mov r3, r0
8052478: f851 6f08 ldr.w r6, [r1, #8]!
805247c: 684c ldr r4, [r1, #4]
805247e: 42a2 cmp r2, r4
8052480: bf08 it eq
8052482: 42b3 cmpeq r3, r6
8052484: bf18 it ne
8052486: 3001 addne r0, #1
8052488: 3301 adds r3, #1
805248a: f142 0200 adc.w r2, r2, #0
805248e: f5a3 1400 sub.w r4, r3, #2097152 ; 0x200000
8052492: 4314 orrs r4, r2
8052494: d1f0 bne.n 8052478 <OspiHypRamTest+0xc8>
8052496: f3bf 8f5f dmb sy
805249a: f3bf 8f4f dsb sy
805249e: 4b27 ldr r3, [pc, #156] ; (805253c <OspiHypRamTest+0x18c>)
80524a0: 685b ldr r3, [r3, #4]
80524a2: b662 cpsie i
80524a4: 1b5b subs r3, r3, r5
80524a6: ed9f 6a26 vldr s12, [pc, #152] ; 8052540 <OspiHypRamTest+0x190>
80524aa: 4a29 ldr r2, [pc, #164] ; (8052550 <OspiHypRamTest+0x1a0>)
80524ac: ee07 3a90 vmov s15, r3
80524b0: eef8 7a67 vcvt.f32.u32 s15, s15
80524b4: eec6 6a27 vdiv.f32 s13, s12, s15
80524b8: ee26 7a87 vmul.f32 s14, s13, s14
80524bc: ed82 7a00 vstr s14, [r2]
80524c0: bdf8 pop {r3, r4, r5, r6, r7, pc}
80524c2: 2200 movs r2, #0
80524c4: 481d ldr r0, [pc, #116] ; (805253c <OspiHypRamTest+0x18c>)
80524ca: f46f 1c00 mvn.w ip, #2097152 ; 0x200000
80524ce: 6845 ldr r5, [r0, #4]
80524d0: 4616 mov r6, r2
80524d2: 4610 mov r0, r2
80524d4: f851 4f08 ldr.w r4, [r1, #8]!
80524d8: 684f ldr r7, [r1, #4]
80524da: 42ba cmp r2, r7
80524dc: bf08 it eq
80524de: 42a3 cmpeq r3, r4
80524e0: bf18 it ne
80524e2: 3001 addne r0, #1
80524e4: 3b01 subs r3, #1
80524e6: f162 0200 sbc.w r2, r2, #0
80524ea: 42b2 cmp r2, r6
80524ec: bf08 it eq
80524ee: 4563 cmpeq r3, ip
80524f0: d1f0 bne.n 80524d4 <OspiHypRamTest+0x124>
80524f2: e7d0 b.n 8052496 <OspiHypRamTest+0xe6>
80524f4: 2200 movs r2, #0
80524f6: f04f 33ff mov.w r3, #4294967295
80524fa: f46f 1e00 mvn.w lr, #2097152 ; 0x200000
80524fe: 4610 mov r0, r2
8052500: 1e5c subs r4, r3, #1
8052502: f84c 3f08 str.w r3, [ip, #8]!
8052506: f8cc 2004 str.w r2, [ip, #4]
805250a: f162 0200 sbc.w r2, r2, #0
805250e: 4623 mov r3, r4
8052510: 4282 cmp r2, r0
8052512: bf08 it eq
8052514: 4574 cmpeq r4, lr
8052516: d1f3 bne.n 8052500 <OspiHypRamTest+0x150>
8052518: e77e b.n 8052418 <OspiHypRamTest+0x68>
805251a: f04f 4110 mov.w r1, #2415919104 ; 0x90000000
805251e: e763 b.n 80523e8 <OspiHypRamTest+0x38>
8052520: 490c ldr r1, [pc, #48] ; (8052554 <OspiHypRamTest+0x1a4>)
8052522: e7a0 b.n 8052466 <OspiHypRamTest+0xb6>
8052524: f3af 8000 nop.w
8052528: a0b5ed8d .word 0xa0b5ed8d
805252c: 3eb0c6f7 .word 0x3eb0c6f7
8052530: 24002cbc .word 0x24002cbc
8052534: 52005000 .word 0x52005000
8052538: 5200a000 .word 0x5200a000
805253c: e0001000 .word 0xe0001000
8052540: 4b800000 .word 0x4b800000
8052544: 3f742400 .word 0x3f742400
8052548: 24002bfc .word 0x24002bfc
805254c: 6ffffff8 .word 0x6ffffff8
8052550: 24002bf8 .word 0x24002bf8
8052554: 8ffffff8 .word 0x8ffffff8
‎2024-10-21 12:43 AM
My biggest worries were actually the different results after compilations, when I didn't touch anything concerning HyperRAM.
This is actually stable since I added that UART wait before starting the test loops.
- « Previous
- 1
- 2
- Next »
