forum displaying posts out of order
trevor23
Posted on June 21, 2010 at 17:29
#falt-view
11 REPLIES 11
Andrew Neil
Evangelist III
Posted on May 17, 2011 at 13:55
''Are others seeing posts out of order?''
Yes, I have been seeing that for a week or two.
For me, the workaround seems to be to switch from ''flat'' to ''Threaded'' mode.
FWIW, I think this forum software is dreadful.
trevor23
Agreed, but what makes it more frustrating is that the old forum worked very well
t1
''FWIW, I think this forum software is dreadful.''
Agreed, although I've seen a lot worse.
picguy2
Forum s/w should default or at least remember thread view.  Larger font size would help.  Also not going to top after reading a post halfway down.
Andrew Neil
Evangelist III
It does!
Doesn't look like anyone's going to own-up to what went wrong, or say what had to be done to fix it, though...
trevor23
seems to be working correctly again
PeppeST
Hi ,
the correct Flat View sorting configuration setup has been put back.
So, it should be OK now.
Ciao
Peppe
trevor23
Great, thanks for the explanation
t1
Doesn't seem to be fixed completely.  The topic
''Code causes hard fault, can anyone guess why'' is still out of order for me.
