W5100 Ethernet Chip SPI code
‎2010-06-21 8:30 AM
‎2011-05-17 4:55 AM
''it doesn't go very well''
What, exactly, do you mean by that?A complex system designed from scratch never works and cannot be patched up to make it work.
‎2011-05-17 4:55 AM
I doesn't get any sign of life from it...
So maybe the SPI isn't set up properly or maybe it's just me that haven't ported it correctly.
I've uploaded the code - keep in mind that it is a mix of my fully working LCD library/interface which I use for debugging, and the not working ported W5100 code!
Download it here: http://elec.tkjweb.dk/SSD1963_W5100.zip
Best Regards
Thomas Jespersen
‎2011-05-17 4:55 AM
''I doesn't get any sign of life from it... So maybe the SPI isn't set up properly''
Have you checked with a scope that the clock is being generated? And any required chip select? And data on the data lines?A complex system designed from scratch never works and cannot be patched up to make it work.
