Motor speed uncontrollable
tejas_amp
Senior
I am using STEVAL-ESC001v1 and a2212/10t 1400kv motor. While giving it supply and reference signal, the measured speed keep on increasing and the actual speed of motor as well. Also, motor_state stucked at START but motor still running. Please help.
4 REPLIES 4
tejas_amp
Senior
Reply ??
GMA
Hello @tejas_amp,
Did you used MC motor profiler for your motor?
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
Thanks for the reply. I had used Motor Profiler, it showed "Profiling taking too much time", following the ST Documentation, I tried altering max RPM, max Current values but didn't find any way. Please, please help in figuring this out.
GMA
Hello @tejas_amp,
You can refer to this thread for this topic.
Best regards.
GMA
