issue with controlling dc motor using temperature sensor in proteus
‎2024-08-11 1:11 AM - last edited on ‎2024-08-12 12:24 AM by Amel NASRI
i made a code about controlling dc motor with temperature sensor but something is clearly wrong
here is the code in question
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "main.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
#define TEMP_THRESHOLD 30.0
float temperature = 31.0;
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
ADC_HandleTypeDef hadc1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_ADC1_Init(void);
/* USER CODE BEGIN PFP */
float Read_Temperature(void);
void Control_Motor(float temperature);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_ADC1_Init();
/* USER CODE BEGIN 2 */
HAL_ADC_Start(&hadc1);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
Control_Motor(temperature);
HAL_Delay(1000);
temperature = Read_Temperature();
HAL_Delay(1000);
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @retval None
void SystemClock_Config(void)
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
* @brief ADC1 Initialization Function
* None
* @retval None
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_15CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
* None
* @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_1, GPIO_PIN_RESET);
/*Configure GPIO pin : PA1 */
GPIO_InitStruct.Pin = GPIO_PIN_1;
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
if (HAL_ADC_PollForConversion(&hadc1, HAL_MAX_DELAY) == HAL_OK)
uint32_t adc_value = HAL_ADC_GetValue(&hadc1);
float temperature = (adc_value * 3.3 / 4096.0) * 100.0; // Convert ADC value to temperature
return temperature;
return 0.0;
if (temperature > TEMP_THRESHOLD)
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_1, GPIO_PIN_SET); // Turn on the motor
else
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_1, GPIO_PIN_RESET); // Turn off the motor
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
__disable_irq();
while (1)
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* file: pointer to the source file name
* line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
- Labels:
STM32 Motor Control
‎2024-08-11 3:53 AM
Edit post and paste code properly with </> icon.
Explain what is and what is not happening, provide observations and perhaps instrument with output so you can understand what the MCU sees and does.
‎2024-08-11 4:02 AM
first i don't know how
second, when i start simulating, the motor rotate for 1 second and it stopped
also when i tried to fix the code, the fan didn't work when i exceeded 30 degree, i don't know how and what cause?
i use stm32f401re
‎2024-08-11 5:38 AM
@marwanwahed11 wrote:first i don't know how
Instructions here:
‎2024-08-11 5:49 AM - edited ‎2024-08-11 6:03 AM
* @file : main.c
* @attention
#include "main.h"
* @retval int
int main(void)
HAL_Init();
MX_GPIO_Init();
MX_ADC1_Init();
/* Infinite loop */
while (1)
HAL_Delay(1000);
HAL_Delay(1000);
* @retval None
Error_Handler();
Error_Handler();
* None
* @retval None
Error_Handler();
sConfig.Rank = 1;
Error_Handler();
* None
* @retval None
return temperature;
return 0.0;
else
* @retval None
__disable_irq();
while (1)
* @retval None
when i tried to simulate, the motor rotated for 1 second and stopped, but when i tried to fix the code, the motor was always off even if i exceeded 30 degree. how can i solve this problem?
‎2024-08-11 7:26 AM
Please use uart or usb cdc to print the temperature or adc value to understand what is happening. When there is an error happening, your code should handle it, indicate by led or some method. You have to implement some kind of hysterisis to avoid fluctuating operation...
‎2024-08-12 12:38 AM
i tried usart1 but when i simulated in proteus, visual terminal didn't read anything even though i connected rxd to pa9 and txd to pa10
‎2024-08-12 1:52 AM
@marwanwahed11 wrote:i tried usart1 but when i simulated in proteus, visual terminal didn't read anything even though i connected rxd to pa9 and txd to pa10
So take a step back.
Create a simple project which just does UART output. Get that working first.
For questions about how to do this in Proteus, you are going to have to ask Labcenter - it's nothing to do with ST:
https://www.labcenter.com/tutorials/
https://www.labcenter.com/support/
https://support.labcenter.com/forums/
https://www.labcenter.com/contact/
