Send sensor data from Nucleo-WL55JC1 and X-NUCLEO-IKS01A2 over LoRaWAN
Dada10233
I am working on a project using Nucleo-WL55JC1 and the X-NUCLEO-IKS01A2 sensor board. My goal is to read sensor data (temperature, humidity, pressure, etc.) and send it over LoRaWAN to a network server such as ChirpStack.
I have already connected the X-NUCLEO-IKS01A2 to the Nucleo-WL55JC1 using I2C (SDA = PA11, SCL = PA12). I have enabled I2C2 in STM32CubeMX. The LoRaWAN stack is configured, and the device can successfully join a network.
Now, I need help with the following questions:
  1. How do I correctly read the sensor data from X-NUCLEO-IKS01A2 in my STM32 project?
  2. How should I format and send the sensor data in a LoRaWAN uplink message?
  3. Are there any recommended libraries or example projects for this setup?
Andrew Neil
See the Datasheets for each of the sensors; see also their Product Pages for software
The Product Page for the X-NUCLEO-IKS01A2  also suggests X-CUBE-MEMS1:
https://www.st.com/en/ecosystems/x-nucleo-iks01a2.html
That's entirely up to you - do whatever works for you and for whatever will "consume" the data at the other end
RomainR.
Hello @Dada10233
These video tutorials should help you, especially Lab 4.
https://www.youtube.com/@truestepbystep3763/videos
Let me know if it helps you?
Best regards,
Romain,
