Is it possible to change the MCU in the ST MCSDK?
MotorRunner
Hello everyone!
As far as I know we have just only some limited options when it comes to choosing our MCU in MCSDK.
I am intersted in changing my mcu from a LQFP64 to a LQFP48 one, is it possible for me to choose a different, custom MCU using the board designer? if yes, what are the possible limitation? what consideration should I take into account?
Thank u all
GMA
Hello @MotorRunner,
Using STMC Board Designer, on the original board line, select "Clone this item" and click on "Change MCU". You will be able to select you targeted MCU.
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
GMA
Hello @MotorRunner,
Best regards.
GMA
Hey @GMA
Thanks for your reply, it really worked sir and everything is now configured cubeMX-wise, and the new MCU is STM32F030K6T6.
I will design the PCB(power+ control), and Iet you know if I could get the motor running. Thanks.
