I am getting this error when I try connecting my Hardware ( Nucleo-F302R8, IHM07 ) with STM Motor Profiler. What could be the issue?
‎2023-06-12 4:11 PM
‎2023-06-18 11:43 PM
Hello EOkum.1,
This issue is generally caused by hardware. Nevertheless, have you first tried choosing manually the two boards you are using via the "Select Board" button ?
If the problem persist, consider having a look at your board's jumpers, especially the CN2 jumpers on F302R8, which both need to be set. They allow ST-LINK for onboard programming, which is mandatory for profiler.
Please also keep in mind that profiling is only done on 3-Shunt configurations, and that your IHM07 needs to be configured that way, even though it should not impact ST-LINK connection.
Hoping this will help,
Gaël A.
Hope this will help,
Gaël A.
Hello EOkum.1,
Gaël A.
Gaël A.
