F401RE + IHM16M1
‎2022-08-12 3:17 PM
Hello
I am using the combination of F401RE and IHM16M1 for a project in my lab to drive a 24V BLDC Motor (max RPM 5000).
Issues:
1) I am unable to select the above combination in the Motor Profiler.
2) When I try to generate code using Motor Control Workbench (5.Y), I generate code using CubeMX (6.3) and flash it using CubeIDE (1.10.1) -->I run motor using Motor Pilot but it always says "Speed Feedback Error". I don't know why this happens.
3) No resources about how to make this combination work.
4) I tried using the 6StepLib. However, the motor just spins and then stops making a humming noise (increasing), then stops. Sometimes it doesn't stop but runs at 450-500 RPM.
Can anyone please point me to a given example for this combination? Or am I missing something?
I am new to the ecosystem so I would appreciate any help or guidance. Thank you.
****UPDATE****
GMA,
Thank you for helping me resolve this issue.
All,
For more information about the issue and the solution, please visit: https://community.st.com/s/question/0D53W00001AzMDESA3/environment-mcsdk-5y2-stm32cubemx-630-nucleof446re-is-not-working-compared-to-other-nucleo-boards-while-using-the-same-power-board-bldc-motor-with-the-same-configuration-what-would-be-the-possible-cause-for-this-problem
Very helpful post regarding the compatibility issue between F446 and IHM16M1.
I will try to summarise everything together and make a post sometime soon.
Thank you and regards
Anirudh Chhabra
‎2022-08-24 8:46 AM
Please find attached an example stmcx used to run a test with same configuration F401/IHM16 but with a different motor. I made the same modifications as on F446 forum topic:
- All ADC input have to be checked in "Analog Input and Protection" box, pin map for "Phase current feedback", "Bus voltage feedback" and "Temperature feedback" tabs.
- I removed IHM16 R41 resistance.
- And I also changed the Drive Management / Start-up parameters Profile from "Advanced customized" to "Basic".
Hope it helps you.
Best regards.
GMA
Best regards.
GMA
‎2022-08-16 12:55 AM
For the motor parameters without using profiler:
How To manually configure the motor parameters - stm32mcu
For the speed feedback, please check FAQ speed feedback chapter:
Frequently asked questions (FAQ) - stm32mcu
Best regards.
GMA
Best regards.
GMA
‎2022-08-20 12:04 PM
Hello
I updated the motor parameters as per the motor's datasheet. Both in the motor workbench as well as checked the appropriate header files. All the information and specs are correctly loaded in the IDE.
Here is the motor description: https://lin-docs.s3.us-west-2.amazonaws.com/datasheets/external/bldc/BL17E19-01D-03RO.pdf
However, the error I get is startup failure. The code flashes correctly in the MCU but the motor just hums and runs for almost 1-2 seconds, and stops and shows failure. Even when I modify the code to run it using the MC_StartMotor1(); command.
I saw another post here on the forum that F446RE and similar MCUs (like F401RE) have a pin assignment issue and an ST employee suggested cutting the C10 - 18 pin on the MCU since that is the VCAP pin and changing the pin assignment. I want to know if that is relevant to my MCU+driver combination. Here is the post link:
Also, what is the best way to resolve this issue? I am stuck and looking forward to some help.
Anirudh
‎2022-08-20 12:11 PM
Hello
Here is an update:
Whenever I run the motor using the motor profiler tool, the following happens.
You can see the power measure is off the chart up to 65kW. I don't think that should be correct. But I don't understand why this happens.
Anirudh
Also, here is the log:
[INFO] - : Application is starting : MotorPilot version:0.9.20[INFO] - : ini file path=C:/Users/aniru/AppData/Roaming/ST Microelectronics/ST Motor Pilot.ini
[INFO] - : Polling time out is set to 200 ms
[INFO] - : set qml to : qrc:/GUI/defaultApp.qml
[INFO] - : Register json file path from qml is : C:/Program Files (x86)/STMicroelectronics/MC_SDK_5.Y.4/Utilities/PC_Software/STMotorPilot/RegisterList/RegListSTMV2.json
[INFO] - : Loading registers bank desciption file C:/Program Files (x86)/STMicroelectronics/MC_SDK_5.Y.4/Utilities/PC_Software/STMotorPilot/RegisterList/RegListSTMV2.json
[WARNING] - MotorControlRegistersBank: Register [SCALES_CONFIG] does not exist although a reference on it is requested. Please, load a suitable Register Description file
[INFO] - : Registers bank description loaded successfully
[INFO] - : Load Application qrc:/GUI/defaultApp.qml
[INFO] - : QML Application ready
[INFO] - : Connecting to Board
[INFO] - UART worker: Successfully open port COM3 @ 1843200
[INFO] - : try to configure the board
[INFO] - : Connected to board
[WARNING] - MotorControlRegistersBank: Accessing register [6937] PERF_MAX_CPU_LOAD for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[WARNING] - MotorControlRegistersBank: Accessing register [6873] PERF_MIN_CPU_LOAD for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[WARNING] - MotorControlRegistersBank: Accessing register [6809] PERF_CPU_LOAD for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[WARNING] - MotorControlRegistersBank: Accessing register [977] STOCORDIC_C1 for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[WARNING] - MotorControlRegistersBank: Accessing register [1041] STOCORDIC_C2 for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[WARNING] - MotorControlRegistersBank: Accessing register [1680] DAC_OUT2 for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[WARNING] - MotorControlRegistersBank: Accessing register [1616] DAC_OUT1 for motor 0 resulted in error[5] . Changing register's access accordingly to avoid getting this error again
[ERROR] - MotorControlProtocol: ASPEP_RESP ERROR:CMD_NOK
‎2022-08-20 12:35 PM
Please see my comments below. I am still unable to resolve the issue.
Anirudh
‎2022-08-22 2:21 AM
A short remark, it is mentioned in Motor specification document "Pole Number 6", I assume that it means 3 Pole Pairs...
In Motor Setting WorkBench, "Pole Pairs" is set to 6.
Did you try with 3?
Best regards.
GMA
Best regards.
GMA
‎2022-08-22 7:40 AM
Hello, I tried using 3 pole pairs, and I get the same error - Startup failure. I think I did that before as well because I was confused about the specs too but I did it again and it throws the same error.
Anirudh
Edit: The only difference is that when I select 3 pole pairs, it seems to spin more aggressively as it starts but then again the humming and full stop. Startup failure.
However, thank you for pointing that out. I did check the pole pairs manually, by shorting the two phases and I could feel 18 bumps/clicks.
18 --> 3 phases = 6 poles = 3 pole pairs.
My understanding is correct, right?
Update:
I write the following code inside the while loop:
/* USER CODE BEGIN 3 */
MC_ProgramSpeedRampMotor1(3000/6,1000);//Set the speed to 3000
MC_StartMotor1();//Motor running
HAL_Delay(10000);//Delay 10S
However, the motor still acts the same. Loud rev-up, little spin, humming and full stop. I attached a video of this as well.
Thanks!
‎2022-08-23 8:19 PM
Hello, can you please check my comments below? I posted some updates and a public video link.
Anirudh
‎2022-08-24 5:55 AM
The remarks about F446 topic seems to be also relevant for F401 as both boards share same schematic... Other connections between F401 and IHM16 have to be also verified. I will come back to you...
Best regards.
GMA
Best regards.
GMA
‎2022-08-24 8:46 AM
Hope it helps you.
Best regards.
GMA
Best regards.
GMA
