2022-11-04 8:52 AM
I use a STM32H750 chip and I would like to use the emdedded bootloader with the FDCAN1 interface. AN2606 specifies pins PH13 and PH14 for this version. However, the package I use (STM32H750VBT6 LQFP100) doesn't have these pins exported. Does it mean that there is no FDCAN bootloader option for the 100-pin package?
Thank you in advance for your answer,
Dorian Bignet
2022-11-09 11:02 PM
Hello @DBign.1 and welcome to the Community :),
For STM32H750, you can activate the FDCAN bootloader with only by PH13/PH14 pins.
Kaouthar
2022-11-09 11:02 PM
Kaouthar
2022-11-11 6:40 AM
Ok, thank you very much for your answer.
2025-01-16 3:43 AM - edited 2025-01-16 3:43 AM
What does that mean "you can activate the FDCAN bootloader with only by PH13/PH14 pins."?
@DBign.1 Those pins dont exist right?
2025-01-16 4:09 AM
Same problem, different mcu
FDCAN ROM bootloader pins for stm32H743ZI
2025-01-16 4:33 AM - edited 2025-01-16 4:37 AM
@Javier1 wrote:What does that mean "you can activate the FDCAN bootloader with only by PH13/PH14 pins."?
It means that those are the only pins you can use - you cannot use any other pins.
@Javier1 wrote:@DBign.1 Those pins dont exist right?
Which is, presumably, why the datasheet doesn't mention FDCAN as a bootloader option:
https://www.st.com/resource/en/datasheet/stm32h750vb.pdf#page=25
Similarly for the stm32H743ZI:
2025-01-16 4:41 AM
if you go look into AN2606 youll find there is supposed to be a canbus bootloader for this mcu
2025-01-16 4:43 AM - edited 2025-01-16 4:45 AM
Yes, looks like AN2606 makes some sweeping generalisations - which aren't always true.
My reply in your other thread:
