FDCAN bootloader for STM32H750VB?
DBign.1
I use a STM32H750 chip and I would like to use the emdedded bootloader with the FDCAN1 interface. AN2606 specifies pins PH13 and PH14 for this version. However, the package I use (STM32H750VBT6 LQFP100) doesn't have these pins exported. Does it mean that there is no FDCAN bootloader option for the 100-pin package?
Thank you in advance for your answer,
Dorian Bignet
KDJEM.1
Hello @DBign.1​ ​ and welcome to the Community :),
For STM32H750, you can activate the FDCAN bootloader with only by PH13/PH14 pins.
Kaouthar
7 REPLIES 7
KDJEM.1
Kaouthar
DBign.1
Ok, thank you very much for your answer.
What does that mean "you can activate the FDCAN bootloader with only by PH13/PH14 pins."?
@DBign.1 Those pins dont exist right?
we dont need to firmware by ourselves, lets talk
Javier1
Principal
Same problem, different mcu
FDCAN ROM bootloader pins for stm32H743ZI
It means that those are the only pins you can use - you cannot use any other pins.
Which is, presumably, why the datasheet doesn't mention FDCAN as a bootloader option:
https://www.st.com/resource/en/datasheet/stm32h750vb.pdf#page=25
Similarly for the stm32H743ZI:
https://community.st.com/t5/stm32-mcus-products/fdcan-rom-bootloader-pins-for-stm32h743zi/m-p/762443/highlight/true#M270761
if you go look into AN2606 youll find there is supposed to be a canbus bootloader for this mcu
Yes, looks like AN2606 makes some sweeping generalisations - which aren't always true.
My reply in your other thread:
https://community.st.com/t5/stm32-mcus-products/fdcan-rom-bootloader-pins-for-stm32h743zi/m-p/762452/highlight/true#M270763
