2022-11-04 08:52 AM
I use a STM32H750 chip and I would like to use the emdedded bootloader with the FDCAN1 interface. AN2606 specifies pins PH13 and PH14 for this version. However, the package I use (STM32H750VBT6 LQFP100) doesn't have these pins exported. Does it mean that there is no FDCAN bootloader option for the 100-pin package?
Thank you in advance for your answer,
Dorian Bignet
2022-11-09 11:02 PM
Hello @DBign.1 and welcome to the Community 🙂,
For STM32H750, you can activate the FDCAN bootloader with only by PH13/PH14 pins.
Kaouthar
2022-11-09 11:02 PM
Kaouthar
2022-11-11 06:40 AM
Ok, thank you very much for your answer.
