2024-07-16 04:03 PM
I'm simply trying to do:
but nothing is created despite the return message. Could it be my SD card? I'm able to read from it in 4B mode.
Any suggestions would be gratefully received.
2024-07-18 06:56 AM
It turns out that it was as simple as enabling hardware flow control in the MX. I had been unable to get it to mount without the clock divider being 4, but I imagined that may have been creating timing issues as I see the recommended value is 0. May this have caused underrun issues that hardware flow control can prevent?
Thanks for all your willingness to help.
