2023-11-13 03:40 AM
Hello everyone. The last time I opened a form related to bit timing, I realized that the problem was in the Canbus transceiver. I added 1-2 revisions and replaced it with the MCP2551 transceiver. Even though there is a device on the other side, I get an acknowledgment error and the logic analyzer is as follows.
2023-11-17 07:20 AM
I did but let me do it again
2023-11-17 07:21 AM
thanks
2023-11-22 01:04 AM
Solution: First, I changed the CAN2 mode to loopback and tried to receive data, but I could not receive it. Then I edited the time segment 1 and 2 values and after receiving the data in loopback mode, I tried normal mode and my system worked.
