STM32CubeIDE, STM32U5 : unable to launch the debugger (gdbserver)
‎2021-11-02 9:17 AM
Impossible to launch the debugger with the following configuration:
- STM32CubeIde1.7.0
- Target Nucleo-U575ZI-Q
- ST-link :
- Version: V3J8M3
- Build: Apr 9 2021 20:49:40
See log files
STm32cubeProg 2.8.1 can connect to the board successfully.
What is wrong ?
BUG ?
- Labels:
ST-Link
STM32CubeIDE
STM32U5 series
‎2021-11-05 3:16 AM
Stay below the 8MHz as specified in the errata: https://wiki.st.com/stm32mcu/wiki/STM32CubeIDE:STM32CubeIDE_errata_1.7.0#STM32U5
The lower the better stability.
‎2021-11-02 9:21 AM
maybe you didnt closed the STM32CubeProg session so the gdb server is busy? it happens to me sometimes
‎2021-11-02 10:43 AM
I admit that I have also made this mistake more than once, but not in this case.
thanks
‎2021-11-02 11:12 AM
Can you try to decrease the STLink SWD frequency.
If not better, can you try with OpenOcd gdb server.
Rgds,
Laurent
‎2021-11-05 2:36 AM
@MFred.2​ , did you solve the issue with Laurent's advice?
‎2021-11-05 3:05 AM
Indeed, decreasing the frequency of the St-link seems to improve the connection, but it is not very stable.
The frequency of successful connection varies between 8Mhz and 21Mhz !
I have not encountered this problem on other Nucleo board references.
Frederic
‎2021-11-05 3:16 AM
‎2021-11-05 3:36 AM
thank you for this information,
This problem is therefore already known
I didn't think about reading this errata sheet, sorry
‎2021-11-10 2:32 AM
Thanks @mattias norlander​ for sharing this STM32CubeIDE errata reference. It is helpful to make our community aware about it.
