Problem with STM32F401CCU6 board
Totouan
Hello, I am working on a diy simracing project which use the STM32F401CCU6 board. I just bought this board and It worked fine until today for a reason I ignore. The board is stuck on the red led, the blue led doesn't light up anymore. I can still find the board in the device manager ( picture under ) but not it is not detected as it shall be in game controller configuartor ( picture under ). I can still erase the sketch on STM32 Cubeprogrammer and upload it but when I disconnect it it stays with the red led.
Have anyone any idea on what to do ?
Thanks you for your answers, and sorry for my english which isn't very good !
@Totouan wrote:
But does it really change something ?
It means the chip may not function correctly
@Totouan wrote:
There aren't any other option than to buy a real one ? N
That would be the best route if you want to avoid a load of grief!
eg, see:
https://community.st.com/t5/stm32-mcus-products/blue-pill-stm32f1-board-gets-programmed-through-arduino-ide-but/td-p/667923
https://community.st.com/t5/stm32-mcus-products/debug-blue-pill-with-stlink-v3minie/m-p/711320/highlight/true#M258518
That picture shows that it is stuck in Bootloader mode - ie, it's waiting for you to download firmware.
Because it's stuck in Bootloader mode, it won't be detected as a game controller - or anything else - until you've successfully loaded good firmware.
9 REPLIES 9
What board?
If not an ST board, give link to full description, schematics, etc.
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Where from?
Totouan
So (almost) certainly not a genuine STM32
Totouan
But does it really change something ? There aren't any other option than to buy a real one ? No idea of what to do anyway ?
eg, see:
Totouan
Okay thanks for your time and answer !
Totouan
And do you have any idea of how to unstuck it from the bootloader mode ?
Load some code into it!
You'll have to find out what app(s) is/are required to do that.
Or use an ST-Link (or similar) to program directly.
Totouan
Okay thanks a lot !
