2023-03-11 3:42 AM
STMicroelectronics ST-LINK GDB server. Version 7.3.0
Copyright (c) 2023, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
LogFile Name : C:\Workspace\RTOS_Workspace\001_Tasks\Debug\st-link_gdbserver_log.txt
Logging Level : 31
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Enabled
SWD Debug : Enabled
InitWhile : Enabled
COM frequency = 4000 kHz
Target connection mode: Under reset
Reading ROM table for AP 0 @0xe00fffd0
Hardware watchpoint supported by the target
ST-LINK Firmware version : V2J41M27
Device ID: 0x413
PC: 0x8000c24
ST-LINK device status: HALT_MODE
ST-LINK detects target voltage = 2.90 V
ST-LINK device initialization OK
Stm32Device, pollAndNotify running...
SwvSrv state change: 0 -> 1
Waiting for debugger connection...
Waiting for connection on port 61234...
Waiting for connection on port 61235...
Accepted connection on port 61234...
Debugger connected
GDB session thread running
GdbSessionManager, session started: 1
Debugger connected
GdbSessionManager, session started: 2
Accepted connection on port 61235...
SWV collect poll delay set to 3604µs for baudrate 1894000Hz (buffer size 2048b)
SwvSrv state change: 1 -> 2
Stm32Device, closeDevice() entry
SwvSrv state change: 2 -> 4
GDB session, device event: 5
Stm32Device, pollAndNotify stopped
Stm32Device, closeDevice() exit
------ Switching to STM32CubeProgrammer -----
STM32CubeProgrammer v2.13.0
Log output file: C:\Users\SARAVA~1\AppData\Local\Temp\STM32CubeProgrammer_a22120.log
ST-LINK SN : 0670FF495277504867224633
ST-LINK FW : V2J41M27
Board : STM32F4DISCOVERY
Voltage : 2.90V
SWD freq : 4000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x413
Revision ID : Rev Y
Device name : STM32F405xx/F407xx/F415xx/F417xx
Flash size : 1 MBytes (default)
Device type : MCU
Device CPU : Cortex-M4
BL Version : 0x91
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a22120.srec
File : ST-LINK_GDB_server_a22120.srec
Address : 0x08000000
Erasing internal memory sector 0
Download in Progress:
�������������������������������������������������� 0%
�������������������������������������������������� 100%
File download complete
Time elapsed during download operation: 00:00:00.506
Verifying ...
Read progress:
�������������������������������������������������� 50%
Download verified successfully
------ Switching context -----
Device ID: 0x413
PC: 0x8000c24
SwvSrv state change: 4 -> 2
GDB session, device event: 6
SwvSrv state change: 2 -> 3
GDB session, device event: 3
GDB session, device event: 1
GDB session terminated: Client connection lost
GdbSessionManager, session terminated: 2
Received Ctrl-C from the client
ST-LINK device status: RUN_MODE
Device not halted(0), performing Ctrl-C
GDB session, device event: 4
Device halted
Cleanup session: 2
GDB session disposed: 2
GdbSessionManager, session terminated: 1
GdbSrv, last session terminated, signal dispose
Stopping port 61234
Received stop for port 61234, not accepting new connections.
GdbSrv, deInit entry.
Shutting down...
GdbSessionManager, deInit entry.
SwvSrv state change: 3 -> 1
SwvSrv session thread disposed
Stopping port 61234
GDB session disposed: 1
GdbSessionManager, deInit exit
SwvSrv deInit entry
Stopping port 61235
Received stop for port 61235, not accepting new connections.
SwvSrv deInit exit
Stm32Device, deInit success
GdbSrv, deInit exit.
Exit.
2023-03-11 6:00 AM
And what? Maybe you use pins in code = debug not possible or voltage unstable
2023-03-11 8:26 AM
Which board and chip specifically?
Is it a low pin count device?
Can you connect under reset? Is NRST physically connected in your design?
Can you connect or adjust BOOT0 pin or settings?
Does your code interfere with the SWD pin configuration? Disable it, or go into a low power mode?
Problems are hard to troubleshoot without context to work from. Elaborate
2023-04-01 1:51 AM
Board : STM32F407VG MCU * New order code STM32F407G-DISC1
I am trying to integrate freeRTOS and run a sample program using SWD pin. I am getting the below error and log(partial)
[3.688] spawnCubeProgrammer(): 13:52:50:876 Download verified successfully
[3.688] spawnCubeProgrammer(): ------ Switching context -----
[3.693] reset_hw_wtchpt_module(): Hardware watchpoint supported by the target
[3.693] Device_Initialise(): SWD frequency = 4000 kHz
[3.693] Device_Initialise(): ST-LINK Firmware version : V2J41S27
[3.693] Device_Initialise(): Device ID: 0x413
[3.693] Device_Initialise(): PC: 0x8001f6c
[3.709] Device_Initialise(): ST-LINK detects target voltage = 2.90 V
[3.709] Device_Initialise(): ST-LINK device status: HALT_MODE
[3.709] initServerContext(): ST-LINK device initialization OK
[3.709] write(): <632> Tx: $OK#9a
[3.709] read(): <632> Rx: $T1#85
[3.709] read(): <632> Rx: $m8001f6c,4#95
[3.709] handlePacket(): Reading 0x4 bytes of memory from addr 0x8001f6c
[3.709] write(): <632> Tx: $dff834d0#63
[3.709] read(): <632> Rx: $m8001f6c,2#93
[3.709] handlePacket(): Reading 0x2 bytes of memory from addr 0x8001f6c
[3.709] write(): <632> Tx: $dff8#68
[3.709] read(): <632> Rx: $m8001f6e,2#95
[3.709] handlePacket(): Reading 0x2 bytes of memory from addr 0x8001f6e
[3.709] write(): <632> Tx: $34d0#fb
[3.727] read(): <632> Rx: $qXfer:threads:read::0,bfb#fb
[3.727] write(): <632> Tx: $l<?xml version="1.0"?><threads><thread id="1" core="0" name="main"></thread></threads>#8b
[3.789] read(): <632> Rx: $m8001800,40#5e
[3.789] handlePacket(): Reading 0x40 bytes of memory from addr 0x8001800
[3.789] write(): <632> Tx: $02affef765fe00f041f800f0a9f807f10803019302230093174bc8221749184801f052f978617b69012b09d04ff0500383f31188bff36f8fbff34f8f3b61fee7#f0
[3.789] read(): <632> Rx: $m8001802,2#2e
[3.789] handlePacket(): Reading 0x2 bytes of memory from addr 0x8001802
[3.789] write(): <632> Tx: $fef7#68
[3.804] read(): <632> Rx: $Z1,8001802,2#78
[3.805] write(): <632> Tx: $OK#9a
[3.805] read(): <632> Rx: $vCont;c#a8
[3.805] SWV_SetStatus(): SWV_SetStatus(true): stop_reply_pending == 0
[3.820] handle_vCont_c(): handle_vCont_c, continue thread
[3.820] write(): <632> Tx: $OK#9a
[3.836] SWV_SetStatus(): SWV_SetStatus(false): stop_reply_pending == 1
[3.836] handleGDBConnection(): TraceCaptureStart and SWV event set to APP_FALSE (0)
[3.852] Device_GetHaltReason(): NVIC_DFSR_REG = 0x0000000A
[3.852] write(): <632> Tx: %Stop:T05hwbreak:;thread:1;core:0;#7e
[3.852] read(): <632> Rx: $vStopped#55
[3.852] write(): <632> Tx: $OK#9a
[3.852] read(): <632> Rx: $g#67
[3.852] write(): <632> Tx: $000000207800000000000008b5010008000000000000000000000000e0ff01200000000000000000000000000000000000000000d8ff0120a31f0008021800080000006100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000d8ff012000000000#e0
[3.870] read(): <632> Rx: $qXfer:threads:read::0,bfb#fb
[3.870] write(): <632> Tx: $l<?xml version="1.0"?><threads><thread id="1" core="0" name="main"></thread></threads>#8b
[3.870] read(): <632> Rx: $z1,8001802,2#98
[3.870] write(): <632> Tx: $OK#9a
[3.871] read(): <632> Rx: $m8001802,4#30
[3.871] handlePacket(): Reading 0x4 bytes of memory from addr 0x8001802
[3.871] write(): <632> Tx: $fef765fe#9e
[3.878] read(): <632> Rx: $T1#85
[3.878] write(): <632> Tx: $OK#9a
[3.899] read(): <632> Rx: $qXfer:threads:read::0,bfb#fb
[3.899] write(): <632> Tx: $l<?xml version="1.0"?><threads><thread id="1" core="0" name="main"></thread></threads>#8b
[5.359] read(): <632> Rx: $m2001ffc0,40#1f
[5.359] handlePacket(): Reading 0x40 bytes of memory from addr 0x2001ffc0
[5.359] write(): <632> Tx: $a5a5a51d05000000c40000200200000000000000f004002000ed00e0185000080000000014500008b501000825460008000000000000000000000000a31f0008#e5
[5.359] read(): <632> Rx: $m8001fa2,4#8f
[5.359] handlePacket(): Reading 0x4 bytes of memory from addr 0x8001fa2
[5.359] write(): <632> Tx: $70470000#92
[5.359] read(): <632> Rx: $m8001f40,40#90
[5.359] handlePacket(): Reading 0x40 bytes of memory from addr 0x8001f40
[5.359] write(): <632> Tx: $80b400af084bd3f88830074a43f47003c2f88830044b4ff000629a6000bfbd465df8047b704700bf00ed00e0dff834d0002103e00c4b5b58435004310b480c4b#94
[5.359] read(): <632> Rx: $m8001fa4,4#91
[5.359] handlePacket(): Reading 0x4 bytes of memory from addr 0x8001fa4
[5.359] write(): <632> Tx: $00000220#84
[5.453] read(): <632> Rx: $m2001ffc0,40#1f
[5.453] handlePacket(): Reading 0x40 bytes of memory from addr 0x2001ffc0
[5.453] write(): <632> Tx: $a5a5a51d05000000c40000200200000000000000f004002000ed00e0185000080000000014500008b501000825460008000000000000000000000000a31f0008#e5
[14.092] read(): <632> Rx: $vCont;c#a8
[14.092] SWV_SetStatus(): SWV_SetStatus(true): stop_reply_pending == 0
[14.110] handle_vCont_c(): handle_vCont_c, continue thread
[14.110] write(): <632> Tx: $OK#9a
[14.110] read(): <632> Rx: $T1#85
[14.126] Device_GetStatus(): ST-LINK device status: RUN_MODE
[29.648] read(): <632> Rx: $vKill;a410#33
[29.648] handlePacket(): Hidden/Unsupported v-command 'vKill', see RSP for details
[29.648] write(): <632> Tx: $#00
[29.648] read(): <632> Rx: $k#6b
[29.648] stop(): Stopping port 61235
2023-04-01 6:24 AM
For what you need SWV. ?
2023-04-04 5:47 AM
Sorry, it is not SWV. Confiured SWO pin for supportinng printf style debugging
2023-04-04 6:35 AM
Hello @SNaga.6 ?
Could you, please, attach a screenshot of the debug configuration.
Thanks,
Rim
2023-04-04 9:23 AM
Check SB12 for SWO/PB3 operation
