I am working with a stm32l452rct6 microcontroller and when power is connected, the microcontroller is immediately in boot mode. St-link v2 also does not connect. What should I do?
‎2022-04-09 2:50 AM
This is scheme for debug with swd
How to do active sw-dp with st-link v2 and stm32cubeProgrammer?
ST-Link
STM32CubeProgrammer
STM32L4 series
‎2022-04-09 3:01 AM
How do you know it's in boot mode?
Try to connect under reset.
If you can connect through some of the bootloader protocols, check the option bytes.
‎2022-04-09 3:25 AM
I add second question. Gow to do active sw-dp with st-link v2 and stm32cubeProgrammer?
‎2022-04-09 3:28 AM
Check a SWCLK pin it should be Pull-down at Reset state about 10K value.
‎2022-04-09 3:36 AM
Check part orientation
Check VDDA/VSSA
Check BOOT0
Check NRST
​Check VTarget goes to pin 1 or 2 of ST-LINK
N​o magic options, should work out of the box unless something wrong with device.
‎2022-04-09 6:08 AM
i don't connect only vdda and vssa, is it problem? do you know, how to solve this problem? Not connecting in my PCB, i need to rebuild PCB?
‎2022-04-09 6:45 AM
VDDA/VSSA power the PLLs and POR circuits, not just DAC/ADC
Without power, will clamp device in reset, you'll see NRST held low
Perhaps you can solder on some fine wires to test/check
‎2022-04-13 7:16 AM
Hi @DPavl.1​ ,
You can refer to AN4555 Getting started with STM32L4 Series and STM32L4+ Series hardware development for details about good setup mainly for power supply and debug management.
-Amel
