Hi, I am an assistant professor at Dept. of EE.
I tough embedded system courses with Nucleo-64 F401 board. I want to use the newer evaluation board for the course which has a CAN controller. Is there a recommendation for it?
‎2021-06-07 9:34 PM
‎2021-06-08 12:09 AM
do you need the builtin canbus transceiver also?
‎2021-06-08 12:29 AM
If possible, it's the best option. However, I can use the external transceiver.
More important one is the budget which is less than 200$ / EA.
‎2021-06-08 1:10 AM
200$is more than enough i believe.
I dont know any stm32 official board with builtin canbus transceiver. Maybe some ST employee should answer your question.
If i were the one choosing i would pick the latest version of their nucleo-64 f401 board and two of those cheap canbus transceivers.
The entire setup shoulnd cost more than 30$ per student (cheaper if you do big orders)
‎2021-06-08 1:40 AM
Thanks for the quick response.​
One problem is that there is no built-in CAN controller in STM32F401xE (MCU of Nucleo-64 F401 board). That's why I am looking for the different evaluation board.
‎2021-06-08 5:06 AM
‎2021-06-08 5:46 AM
1. Get some CAN analyzers.
- Seeed works and low cost (on Digikey): https://www.seeedstudio.com/USB-CAN-Analyzer-p-2888.html
- None of the CAN Analyzers I've used had a very nice UI, so...
- Recommend that first thing you do is program your Demo board to be a CAN Analyzer, outputting deciphered packets on UART and USB VCP, and allowing single char typing to trigger different CAN Tx packets (This is a useful project students can keep in their own toolkit, my EE work term students have done it).
2. We used NUCLEO-L476RG(STM32L476RG) for CAN experiments.
- We now have custom PCB with CAN using STM32L496, upgrade from L476
- We switched from STM32F4 to L4 series because the older F4 didn't have DE for RS-485
- The STM32L476RG-Discovery has lots more, but costs more.
- Check latest available demo boards (Digikey, Mouser...).
3. FYI
- I find it very useful to pair a breadboard with a Nucleo, and have students (and myself) wire & test circuits like CAN, USB VCP, etc. before ordering PCBs, even new EE's should still learn to breadboard, and pairing with a demo board means breadboard freedom, less flakey wiring, while still getting latest tech/MCU.
- Add some buttons and LEDs on breadboard just so they get a clue of real life circuits (Debounce, MCU pin current limits, etc.)
- And this set of ancient ref material is great for simple getting started (Engineer's Notebooks):
http://thelukens.net/science/electronics/Engineer%27s%20Mini-Notebooks/
Paul
‎2021-06-08 6:10 AM
This is a very interesting board, i migth buy some
‎2021-06-08 6:56 PM
Thanks for the information! This is a cheap and an interesting board! I will check it out.
‎2021-06-08 7:03 PM
Good information! Prototyping is important technique to the engineer. I will check those boards also. I appreciate your help.
