Failed to program STM32H743ZI2 board and Debug terminal also get hang with USB isolatorfrom Linear technology
‎2024-11-27 6:28 AM - last edited on ‎2024-11-27 6:51 AM by mƎALLEm
I expected to connect my PC to a nucleo STM32H743ZI2 board via a USB isolator (Linear technology) but failed.
While, I can connect to the nucleo board directly without isolator and programme it.
Beside, the PC can recognize the STLink from nucleo board correctly, which means the device can be found in the 'Device Manager'.
Using zephyr openOCD for flashing the code but getting below error
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: read version failed
in procedure 'init'
I also tried with IAR IDE but not getting code flash and also debug default terminal is also hang after some time
I'm wondering what's wrong, anyone can help?
Many thanks​
- Labels:
ST boards
ST-Link
STM32H7 Series
‎2024-11-27 6:46 AM
@mÆŽALLEm wrote:Is this what you are using?: https://www.analog.com/media/en/technical-documentation/user-guides/dc2092a_ltp2884fa.pdf
@DhirajThakur If so, pay attention to:
Are you sure that you have sufficient power for your Target?
‎2024-11-27 6:33 AM - edited ‎2024-11-27 6:42 AM
@DhirajThakur wrote:I expected to connect my PC to a nucleo STM32H743ZI2 board via a USB isolator (Linear technology) but failed.
While, I can connect to the nucleo board directly without isolator and programme it.​
Which does suggest that the isolator is the problem.
Do any other USB devices work via this isolator?
@DhirajThakur wrote:Beside, the PC can recognize the STLink from nucleo board correctly, which means the device can be found in the 'Device Manager'.​
Is that with or without the Isolator?
@DhirajThakur wrote:Using zephyr openOCD for flashing the code but getting below error
What about with STM32 CubeIDE and/or CubeProgrammer ?
@DhirajThakur wrote:I also tried with IAR IDE but not getting code flash ​
Again, is that with or without the Isolator?
‎2024-11-27 6:40 AM
Hello @DhirajThakur and welcome to the community,
Indeed you need to check that "USB isolator" first .. Try it with other USB devices ..
‎2024-11-27 6:46 AM
‎2024-11-27 6:57 AM
+ If so,
Check ILIM LED.
Did you connect an auxiliary power supply (12V) to increase the power?
