2021-09-27 10:05 PM
I want to test on the capture module to find out the pulse width of arrived pulses at timer pins in my real application. So, here I want a development board for the STM32L475 to work on this application like generating pulses from one-timer PWM and loop back to another timer capture module. Can you help us find the development board? I have not found anything better on the web.
2021-09-28 02:26 AM
Alright @Community member , my fault:
Another board which is active is B-L475E-IOT01A (STM32L4 Discovery kit IoT node, low-power wireless, BLE, NFC, SubGHz, Wi-Fi).
-Amel
2021-09-27 11:33 PM
I think you may find development board of similar MCU like STM32L476G-EVAL - Evaluation board with STM32L476ZG MCU - STMicroelectronics for your test. thanks!
2021-09-28 01:41 AM
Probably any devboard will allow you to exercise the timers, so the significantly cheaper https://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-mpu-eval-tools/stm32-mcu-mpu-eval-tools/stm32-nucleo-boards/nucleo-l476rg.html#sample-buy should be OK too.
Point is, the 'L475 and 'L476 differe only in that 'L476 has an extra segmented-LCD controller.
2021-09-28 02:10 AM
Hi @Community member ,
To proposals from @QSHAO.1 & @Community member , I add Discovery kit with STM32L476VG MCU 32L476GDISCOVERY.
For the previously suggested boards, there are already some ready to use examples for InputCapture & PWM_Output. You can start with testing them separately then try to merge them in one project.
Examples are in following paths:
If you would like to develop your own project for Timer use starting with STM32CubeMX, you can refer to following videos:
-Amel
PS: Once your question is answered, please click on "Select as Best" for the comment containing the answer to your initial question.
2021-09-28 02:13 AM
2021-09-28 02:23 AM
This board is discontinued now
2021-09-28 02:26 AM
-Amel
2021-09-28 02:56 AM
Thank you I just ordered the same now.
