Cannot connect to B-U585I-IOT02A Discovery kit for IoT node with STM32U5 series
psabela
All of a sudden,  I cannot connect to this board via stlink usb cable.  I tried pressing reset button, updated firmware, connect in every possible mode (hardware reset, core reset).  Is there a combination/sequence of pressing buttons? In other stm32 mcu I saw  a way to erase memory by connecting a resistor to reset pin and  ground momentarily.  Can this be done on this board and how?   Anything else i can try before I trash it?   Thank you for your help!
1 REPLY 1
KDJEM.1
Hello @psabela,
Could you try with another USB cable? Which error did you get?
I recommend you to look at these FAQs:
These articles describe tips to prevent or fix errors encountered when connecting the STM32 target board to your computer.
I hope this will help you to solve the issue.
Thank you.
Kaouthar
