Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
RUN command in STVD doesn`t work
Posted on February 26, 2017 at 10:17HiI`m new with the STM8S-Discovery and the STM8S105.I usually write my code in assembler so I get a deeper touch on the micros hardware.But I encountered an issue with the STVD tool.When I`m entering the debug mod...
Timer4 not respohding as expected
Posted on March 01, 2017 at 12:09Hello,  I am trying to  make a 200us pulse,using simple time dealy.  I am using TIMER4 to create delay. But the problem is whatever prescalar I  use or  What ever Autoreload value I have timer always gives 12us pulse...
PIN state change problem
Posted on March 01, 2017 at 07:56Hello, I   am trying to  create  100us seconds pulse which periodically triggers  a triac. Timer 1 is used for periodic delay and a while loop is under the  timer1 isr for 100us pulse. Problem is it is not working,In...
STM8S003f3p6 pin state change problem
Posted on March 01, 2017 at 07:47Hello,   I   am trying  to make  narrow pulse  using timer1 of stm8s003f3p6, without using any kind of pwm(because my application  doesn't permit me to do that). Program is,timer will make PIN 18 of mcu high the a  w...
ds1307
Posted on February 28, 2017 at 10:22hello,i am trying to interface ds1307 with my stm8s105c6 discovery i am not getting from where should start. i am not getting a clear idea that how rtc works. I was trying to find any library for stm8s of ds1307. ...
