Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Issue with overflow
Hi, this is the map file just before overflow.https://dumptext.com/x6lV7kAFHow can I read this file? Someone could please give me some insight?If a just add one more equation to the code it gets an overflow.I'm using this toolhttps://www.st.com/en/ev...
mcarv by Associate
  • 785 Views
  • 0 replies
Resolved! Customizing web pages on the SPWF01SA
Hi,I'm using the STEVAL-3DP001V1 which has a SPWF01SA module on it. The default firmware of the module has some webpages already prepared for the 3D printing application. However I would like to customize these (or even make my own) webpages. In the ...
Kraal by Lead
  • 1566 Views
RTC wakeup not working
Hi,I have a code that is using STM8L151C6 MCU. I'm using the RTC to wake up periodically from Halt, but for some reason when I use SPI when I'm in RUN mode , after some duration the RTC stops generating the wakeup interrupt.when I comment the SPI pro...
udilevy by Associate II
  • 898 Views
  • 0 replies
SWIM issue with STM8L051F3
Hi,I have one issue in the usage of download function with STM8L051F3,it is sometimes failed, and it made "protection error" with IAR embedded Workbench IDE,I update my schematic, please help to check it,thanks.
We need your assist and solve for quality issues of ST's IC (L7812CV-DG), according to our client's feedback which kind of defective IC(no voltage drop value and no voltage output) is always add.
There are our test and verify procedure of defective IC as following:Our terminal client found IC function disabled issues(no voltage drop value and no voltage output) and feedback------- engineer found disabled IC through confirmation and analysis( ...
ALI.30 by Associate
  • 1318 Views
  • 0 replies
