Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! ST33KTPM2XSPI datasheet
Hi, How can I get the datasheet for ST33KTPM2XSPI? I have contacted tpmsupport@list.st.com like stated in the data brief, but looks like the address doesn't exit. Who can I contact regardng this? Thank you and best regards,Tomislav
tom_tom by Associate
  • 544 Views
  • 1 kudos
Arduino: STM32G0B1 Emulated EEPROM
Post edited to follow the ST community rules. Please use </> button to paste your code. See this post.Hello All I'm working on an load cell based solution using ADS1232 as AFE. Due to the constraints, we have not used external EEPROM. IDE- Arduino ID...
Mayank_K by Associate
  • 1686 Views
  • 3 replies
  • 3 kudos
ST M41T01 RTC
Hello Forum members,I am using ST M41T01 RTC in one of my products. I observed a strange behavior when I remove the coin cell and other power to the RTC. I configured the RTC for today's time, say 10 Jun 2025 and kept it running for an hour. It was w...
AEPL_ST by Associate
  • 1224 Views
  • 3 replies
Resolved! WeAct BluePill: TIM3 on pins PB0 and PB1 not working
Split from WeAct BluePill + : SPI1 does not work (works with older generic BluePills !) - which is marked as solved.Please keep to one question per thread.finally : unfortunately notlots of things are working , but now , timer3 on pins PB0 and PB1 do...
mwalt.3 by Associate III
  • 670 Views
  • 1 replies
  • 2 kudos
stm8 using AWU/HALT/EXTI
I am building time lag switch- i have at42q1010 touch ic connected to PA3- i have stm8s003f3 mcu- Using latching relay to conserve power- timeout is my pot value- Exti on at42q1010 rising edge exti_cr1 =0x01; ( the ic reads low when no touch and when...
mag1_eng by Associate
  • 2743 Views
  • 0 replies
