2024-10-13 2:20 AM - last edited on 2024-10-14 3:47 AM by Peter BENSCH
Hello and respect, I downloaded the stv0900 data sheet from the site and it was 5 pages, and unfortunately there was no information about the stv0900 pins in it, is it possible to send me the complete document? I need information about its pins and connections so that I can design its circuit and use it for a demodulator in my board.
2024-10-16 8:42 AM
Correct, there is nothing officially available from STMicroelectronics anymore.
2024-10-14 3:50 AM
The STV0900 was discontinued a long time ago, apart from the data brief there is no more information about it.
/Peter
2024-10-16 8:11 AM
Thank you for your answer. Does that mean there is no way to find the complete data sheet and document related to this part?
2024-10-16 8:42 AM
2024-10-16 8:57 AM
This class of device is also likely behind NDA/SLA which preclude the distribution of IP and related documentation. ie only to top-tier STB makers when it was an active product. I also expect related staff have been let go or reassigned.
Expect to have to reverse-engineer anything you need.
