Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
stm8s001j3 pin 6 not set output mode
HiI am using STM8S001J3 controlleron my project and I'm have some problem about it,6 pin GPIOB 4 It doesn't work.I don't know how to solve it.Please help me..//example code GPIO_DeInit(GPIOB);GPIO_Init(GOIOB,GPIO_PIN_ALL,GPIO_MODE_OUT_OD_HIZ_LOW);whi...
VP by Associate II
  • 1353 Views
  • 1 kudos
Programing STNRGPF01 (EVAL-IPFC01V1) how?
Hi All,I am trying to program STNRGPF01 (EVAL-IPFC01V1), but I have no success so far. I connectedFTDI serial cable to programming connector, but STNRGPF01 programming tool stays in a loopwithout any results. I also found some ld post about this, but...
STEVAL-ISB044V1 cannot communicate with ST-Link V2
I'm using theᅠSTEVAL-ISB044V1 evaluation board for the wireless charging test. The evaluation board is based on STWBC-EP and can be programmed with ST-LINK V2. STM8AF6166 is the core of it, so I post here. I tried to program the board, and there's al...
Dilemma by Associate II
  • 1072 Views
  • 0 replies
STM8 is little endian - right?
I have started writing some STM8 code in assembler and happened upon a memory assignment issue I can't explain.Globally I have segment 'ram0'Test_Word ds.w in code: ldw X, #$48 ldw Test_Word , X The two bytes of memory at location Test_Word i...
Joe.H by Senior
  • 1599 Views
Remove ROP protection on STLUX385A using ST-LINK
Hello.I have accidentally activated the ROP protection on some demo boards using STLUX385A.Normally I use ST Visual Programmer to restore the configuration bytes, but the STLUX385A is not currently supported.I own a ST-Link V2 but I can't find any fl...
SStei by Associate
  • 1437 Views
  • 1 replies
