Resolved! how to change the work space name
hi,here i am using the stvd studio .i want to change my workspace name .how can i change it.
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
I'm trying to get a datasheet of PSD813F2A-90J in the following site, but I couldn't find the correct datasheet there.https://www.worldwayelec.com/pro/stmicroelectronics/psd813f2a-90j/5183742https://www.worldwayelec.com/pro/stmicroelectronics/psd813f...
Hello, I'm trying to implement a simple frequency counter. The idea is I have some external signal sitting at 6MHz, and I want to measure it by simply starting the TIM1 counter, waiting 1ms (delay), then reading the count, which I'd expect to be abo...
Hello, Can you please suggest a drop-in replacement for the part: PSD4256G6V-10UI This seems to be a obsolete part.Thank you very much, Bijith
Hello Community,I just bought a few of STM8S001J3 for testing.I want to use the halt-mode to get the lowest power consumption. The problem is that setting the Processor in halt, current is still at about 240uA (too much).I was testing about ten of th...
It is on a smart turbo trainer PCB and I need to replace it. any help would be much appreciated EEG3 729Andras
Hello everyone, I really need help in using STM32Cube IDE and TrueAtollic Studio. I have searched up and down on YouTube, and I haven't found a single good video on how to use these IDE's. So I am using a STM32F030R8T6 and ST-Link V2 programmer-(http...
Hi,Ive been trying to use eDesignSuite to verify my design with L6983N50QTR. Please find my schematic attached. My specs are:ICL6983N50QTRTopologybuckInput7 - 33 VOutput 15 V (2 % ripple) - 1.9 A maxWhen I put the values that I am trying to use, I ge...
It worked only one time. after that it is failing in downloading the data.
