Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
when i am trying to compile ST Visual develop 4.3.12 with cosmic compiler 4.4.9.0 it is showingthat the executable could not be found you can fix it by editing your too lset settings.i try to set root path as C:\Program files\cosmic\ fse_compilers\C...
From the point of view of firmware in microcontroller, which is communicating with STUSB4500 by I2C, how can it find out what PDO (voltage and current) has been negotiated with the power source.I am particularly interested in maximum current so the m...
We are running a CAN Bus at 20 kBaud and with different settings it generates error frames on receiving CAN messages. So we found a setting which seems to work. But we want to verify why and if this is a solid solution. We did meassure incoming mess...
Hi i am starting firmware development on STM8 based MCU. For that in need Cosmic C compiler but after its installation , for generating the key when i choose option "on the web"it does not send any mail to my registered Email address and if i choose ...
Hello Guys,I have a small problem in my STM8L device. My current remains in 30µA even in the halt mode (I would like to obtain 10-15µA). What are the ways to drop this value? I have tried to put a serial resistor to increase the total resistance of t...
STM8S001j3 SWIM PIN Not work, After hex file download (IAR EWSTM8 Compiler)8 pin port (SWIM) How to do in the firmware IAR.-DATASHEET 12page-Recommendation for SWIM pin (pin #8) sharingAs the NRST pin is not available on this device, if the SWIM...
Please, anyone has EZCV621 IC Datasheet?
