Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
I2C error handle in cosmic compiler.
Hi there.I´m using a STM8S207 with cosmic compiler.I am reading and writing a 24L64 eeprom thru i2C and everthis is working well.But i want to put protection in the routines to avoid lock the program in case of fail of a write or read command.i found...
MGarb.5 by Associate II
  • 2203 Views
Resolved! PN SD1528, Suffix "R1"
Hello,I am trying to find any info on obsolete RF transistor MPN SD1528-08R1. I have the datasheet for the base PN itself but I cannot find any documentation that contains or defines the suffix "R1".Any help would be greatly appreciated.Thanks,-Adam
ABend.1 by Associate
  • 1219 Views
Wifi Web Server
Hi All, I need to build a solution with a Web Server with Wifi interface.I need to write html pages and so on, and drive an UART (implementing simple commands with a custom protocol).What ST evaluation board do you suggest me?
marco2 by Associate III
  • 4948 Views
  • 5 replies
