Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! STGAP2SMTR pin configuration regd
We have recently bought the STGAP2SMTR from DIGIKEY. The pictures of the same is attached to this. I am unable to figure out which pin is pin number 1 (there is no DOT in the IC). Please can you look at the pictures and let me know which is the pin n...
Resolved! Finding a suitable Mosfet
I am working on reparing a battery charger for a campervan and searching for a replacement for Mosfet partnumber h7na80fi.Is there any suitable one?
JErik.1 by Associate II
  • 3418 Views
  • 4 replies
  • 1 kudos
Reading mapfiles - a tool for you
I have seen a number of questions about reading the stm8s mapfiles and I was also someone who struggled so the attached tool might be helpful (and do let me know of any errors!).The key elements are:- There are some elements that are stored in ROM ("...
Resolved! STUSB4500 I_SNK_PDO_FLEX
I can’t find a description of this (I_SNK_PDO_FLEX) parameter, what it is for, and what it affects in the decision-making algorithm about the power profile.Thanks.
Stas by Associate
  • 1491 Views
  • 1 replies
  • 1 kudos
STVisual Develop building libraries
I have a very simple main using UART1 and already my application is 7kB!  The web implies that this is because I am getting a lot of UART1 and CLK code built and linked in that I am never using.  One suggestion is to split the UART1 and CLK files int...
Ensure code running in RAM
Ref: stm8s flash entire new program - how? - STMicroelectronics CommunityHow do I ensure that an entire routine, and anything that it might call, is running in RAM?  I think there is a RAM() macro around, for example, the flash write methods so can I...
M29DW128G60ZA6E: ST or Micron?
Hi Peter ,  Good day ,  Here the part Label is comes with MICRON logo and part markings are belongs to ST micro format . Is it possible ??  Looking forward for your support and advise on this case.  Thank you  Regards  Manoj Balakrishnan.
