Timestamp in binaries
Charles Blanchard
I'm using IAR 6.21. I'm trying to build a static library but even if my sources didn't change, the binary file is different each time I build again the lib.
I tried to compare the lib.a, there is some UNIX timestamps in the file that depends on the build time.
Do you know a way to prevent that? I need to have the exact same binary for the exact same sources...
Thank you,
Charles
11 REPLIES 11
Did they tell you how you actually activate this option in IAR 8.50 ?
BR
Hi! I think so but I'm in vacation until Monday and I will be able to see their answer then.
I suppose it is in the Linker options.
