Tera Term not working with STM32F407VG Board
SPand.25
I have been trying hard to produce a output in TeraTerm & RealTerm using uart2 via GPIO A Pins PA2 & PA3 which are directly connected to St-Linkv2 on my STM2F407VG Disc-1 Board. It just fails to produce anything. I am using STM32Cube IDE and STM32 CubeMX.
Pls Can Anyone help me out of this. I recently did the firmware upgrade to ST-LinkV2.1 and yes I got all the drivers installed already. I also did try to write my own main.c , msp.c and it.c ; still no output on TeraTerm.
Even I was facing the same issue when i tried STM32Duino, the Arduino Ide did not show any Serial output. Well that's for later, I want a solution to Stm32Cube Ide.
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 MX_I2C1_Init();
 MX_I2S3_Init();
 MX_SPI1_Init();
 MX_USART2_UART_Init();
 MX_USB_HOST_Init();
 /* USER CODE BEGIN 2 */
 char* buf = "STM CORTEX M4 \r\n" ;
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
  /* USER CODE END WHILE */
  MX_USB_HOST_Process();
  HAL_UART_Transmit(&huart2, buf, strlen((char*)buf), HAL_MAX_DELAY);
  HAL_Delay(100);
  /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
The pins on the F4-DISCO are not wired to the VCP provided by the ST-LINK. You'd either need to wire them, or use a USB-To-CMOS Serial dongle
