is there any STM32 controller with FPU ? with out changing the hardware i need to replace stm32f030c8t6 with new one with FPU ? .
karthik.b
5 REPLIES 5
Double or Single Precision?
Is that a 144-pin device? Guessing not
Floating point is done in software on CM0 and CM3 parts.
The CM4F has a single precision FPU​ that does some basic math functions, the remainder are handled in the library code.
Without some more specific reasoning, it sounds like you need a redesign.​
Guru
There aren't any that are pin compatible. There are some that are close but have an additional VDD/VSS pair. See the "Pinout compatible" search feature in CubeMX.
Thanks TDK community
Karthik.B
Thanks you clive1
Thanks TDK
